ᐅ How can Ikea Pax be used as storage in a home office?
Created on: 28 Oct 2023 10:07
Fameo
Fameo
28 Oct 2023 10:07
I have a specific question about using the Ikea Pax wardrobe system as a storage solution in a home office: How can Ikea Pax be best utilized to make efficient use of available space for organizing work materials such as documents, stationery, and tech accessories, as well as occasionally books and personal items? I am particularly interested in which internal fittings (drawers, shelves, hanging rods, etc.) are recommended to create a flexible, organized, and space-saving system that supports workflow without appearing cluttered. Are there any practical tips or experiences on how to combine the modules effectively and, if needed, accommodate smaller packages or cable management? Additional question: How does this work in smaller rooms with limited wall space where perhaps only two Pax units fit side by side?
SUBEN60
28 Oct 2023 13:59
Regarding the question of how to optimally use Ikea Pax wardrobes as storage in a home office, I recommend a well-thought-out combination of adjustable interior fittings and clear categorization. Here are some key points based on my experience:
- Drawers from the Pax series are excellent for small items such as pens, notepads, cable adapters, or office supplies. This keeps the surface clear and searching efficient.
- I use shelves for binders and books, but with the ability to adjust the height. This allows the space to be extremely flexible.
- For cable management, it helps to plan cable openings behind the wardrobes or to install additional cable trays to avoid clutter.
- In smaller rooms with only two Pax units placed side by side, consider a combination of open and closed elements. For example, an open compartment at the top for quick access and closed drawers below for less frequently used items.
The Ikea Pax series offers enough modules and accessories for a customized setup that enables clear separation of work tasks while maintaining a tidy appearance.
Laukau5
29 Oct 2023 09:34
SUBEN60 schrieb:
When it comes to cable management, it helps to plan cable openings behind the cabinets or to install special cable ducts to avoid clutter.
This is exactly where careful planning is essential, as Ikea Pax cabinets rarely come with optimized cable management out of the box. I like to proceed step by step:
- First, I measure my devices precisely and consider which permanent connections are needed.
- Then I decide where cables can be routed sensibly, for example by drilling holes in appropriate spots in the back panel of the cabinet. This sometimes requires adjustments because Ikea installs only a limited number of cable openings in Pax units.
- For the interior, I recommend using adjustable-height shelves combined with removable boxes or trays for small items.
- Drawers are generally useful, but if overloaded or too deep, smaller items can quickly become disorganized. Here, dividers or special organizers, which can be purchased separately, are helpful.
- To maintain functionality, I often use a mix of closed and open compartments with medium load, as open ones allow quick access.
- Finally, in compact home offices, it's important to avoid blockages—deep Pax units can appear bulky. The width of 50cm (20 inches) per unit is quite generous; if the room is small, narrower models like 35cm (14 inches) are often a better choice.
One more question: How much space is actually available, and how many work devices need to be integrated?
gasidney
29 Oct 2023 19:27
Laukau5 schrieb:
How much space is actually available, and how many appliances are to be integrated?
In short: Without knowing the exact dimensions and main areas of use, it is difficult to recommend a satisfactory solution. Still, it is best to focus on organization and defined zones rather than fitting in as many drawers as possible – this saves space and improves efficiency.
