ᐅ How can Ikea Pax wardrobes be optimized for textile storage?
Created on: 24 May 2022 18:37
pinduane
pinduane
24 May 2022 18:37
Hello everyone, I am planning to get an Ikea Pax system to better store my textiles such as bedspreads, bed linen, sweaters, and heavily folded shirts. I am especially interested in how to use the Pax system optimally for textile storage, particularly regarding the interior fittings – that is, which combination of shelves, drawers, hanging rails, or baskets works best to ensure both order and clarity. Ideally, I want to keep several types of textiles neatly separated and easily accessible. Do you have any recommendations on how to customize the Pax system as effectively as possible? Are there practical tips to make the most of the available storage space? I appreciate all tips, big or small!
noge58
24 May 2022 20:04
Hey pinduane, it’s great that you chose the PAX system! ☺️ There are so many possibilities! I’ve equipped my PAX with lots of drawers that I use for different types of clothing: thick sweaters at the bottom, bedspreads on top, and everyday clothes always within easy reach in the middle drawers. Really convenient! 👍
It’s important not to cram everything into just shelves. Instead, mix it smartly: drawers, baskets, and shelves. For example, I’d use hanging rods for shirts to keep them wrinkle-free. Baskets are great for socks or underwear to keep things organized.
I also recommend using small dividers—whether homemade or store-bought—to prevent your clothes from getting mixed up. Give it a try; it’s fun, and everything has its place! Good luck! ✌️
Palenar
25 May 2022 07:21
Hello pinduane, your plan to optimize the Ikea PAX system for textile storage requires some careful planning, especially if you want to accommodate different types of textiles. I recommend taking a systematic approach:
- First, quantify the different types of textiles to know the expected amounts. This helps with properly sizing the wardrobe compartments.
- Then consider the combination of interior fittings: drawers are ideal for smaller, folded textiles like underwear and T-shirts. They allow quick access and help keep things organized.
- For sweaters and thicker fabrics, sturdy shelves are suitable, which you should not pack too tightly to reduce wrinkles.
- Bedspreads and bedding work well in larger baskets or pull-out boxes that you place on the upper shelves. Since these are used less frequently, bulkier storage is fine.
- You can use hanging rods inside the PAX system for your shirts, which makes ironing easier and prevents creases.
Another tip: pay attention to the depth of the components. The fact that PAX is 58 cm (23 inches) deep provides enough room for folded textiles, but good organization is important. Use light colors for the interior fittings to make it easier to find things.
A side question: How much space do you have available, and are you planning the wardrobe on its own or to integrate it into an existing furniture setup? This helps in selecting suitable models.
Deandre
26 May 2022 13:42
I can only agree with that. It’s definitely worth carefully considering which clothing items and textiles you mainly want to store. A tip from me: If you often switch between seasons, decide which textiles you need daily and which can be stored seasonally.
To optimize storage, flexible internal organizers might be useful. Some users report that adjustable dividers and pull-out boxes make access easier.
Also, consider ergonomics. Store heavy textiles best at waist or hip height, frequently used items at eye level, and rarely used ones at the top.
If you need more storage options, fabric bags or vacuum bags can also be stored in drawers or baskets to save space. I hope this helps. If you like, I can also assist you with measurements or choosing specific shelves!
