ᐅ How can you install Ikea PAX wardrobes in rental apartments without drilling?
Created on: 4 Jul 2023 08:13
LEXANDER
LEXANDER
4 Jul 2023 08:13
I have an important question regarding furniture fastening in rental apartments – specifically about the IKEA PAX system. How can you securely and stably attach IKEA PAX wardrobes to the wall if you live in a rental property and want to avoid drilling? Since many landlords do not allow drilling into the walls or at least heavily restrict it, I am looking for alternatives that still ensure the wardrobe won’t tip over or become unstable.
I am interested in practical fastening options that don’t cause permanent damage, as well as tips on how to achieve a reasonable level of safety and stability. It would also be helpful if you could share advice on what to consider—for example, the type of flooring, potential residues, or how to create a particularly strong connection without using screws or wall anchors.
I look forward to your experiences and suggestions!
teyosef
4 Jul 2023 10:47
Hello LEXANDER,
I think your question is very well formulated and important, especially since "no drilling" rules are often an issue when securing large furniture like PAX in rental apartments.
Here is a short guide with several alternatives that I or acquaintances have successfully used:
- Tension rod and clamp systems: IKEA often provides a safety system for PAX that can be fixed to the ceiling. If drilling is not allowed, you can use tension rods that support between floor and ceiling. These are height-adjustable and require no holes in the wall. It is important that the ceiling is strong enough and that you place a non-slip protective layer on the floor to prevent slipping.
- Non-slip mats or rubber pads: Placed behind the feet of the cabinet, they help increase stability and prevent tipping, as long as the cabinet is not too tall.
- Furniture connectors between cabinets: If you place several PAX elements next to each other, you can secure them with furniture connectors so they support each other and stand more firmly.
- Adhesive mounts: There are very strong adhesive anchors and double-sided mounting strips, but these are often not designed for heavy loads and can leave residue when removed, which may upset the landlord.
- Centering weight: Place heavy items or books in the lower part to lower the center of gravity.
In conclusion:
The best combination is often a tension rod solution together with furniture connectors and non-slip mats. This provides secure fastening without drilling and without permanent damage to walls or ceiling.
I hope this helps!
CHENFAR
4 Jul 2023 13:25
teyosef schrieb:
Here is a brief guide with several alternatives that I or acquaintances have successfully used:
The points mentioned are very accurate.
Additionally, I would like to highlight the use of so-called “clamping rail systems,” which some manufacturers offer specifically for PAX wardrobes in rental apartments. These systems work without drilling because they clamp against the ceiling and floor using spring force.
Further points to consider:
- The condition of ceiling height and wall structure is crucial. Since not all measurements are exact, the tensioning system should always be supplemented with suitable rubber buffers and anti-slip pads.
- A thorough flatness check of the floor is important to ensure the wardrobe stands securely.
- For very tall wardrobes, there is still a risk of tipping despite clamping, so multipoint fastening to other furniture is recommended.
As an alternative to drilling, you can also use a “rail and hanging system” mounted on the wall with clamping profiles. However, these systems are often more complicated to install and expensive.
I advise paying close attention to the instructions when choosing the fastening method and not exceeding the specified weight limits.
Summary:
- Clamping rods with rubber buffers
- Furniture connectors for linking multiple PAX wardrobes
- Non-slip pads
- Do not use adhesive or hanging profiles without consulting the landlord
A secure drilling-free solution always requires a combination of measures.
Elijah42
4 Jul 2023 17:03
LEXANDER schrieb:
How can IKEA PAX wardrobes be securely and stably fixed to the wall when living in a rental apartment, without drilling?
Tension rods between floor and ceiling are the best solution. Additionally, use non-slip mats. This way, the wardrobe stands firmly without drilling.
Tinaneo
5 Jul 2023 09:11
teyosef schrieb:
There are very strong adhesive anchors and double-sided mounting strips; however, these are often not designed for heavy loads and can leave residue when removed, which may upset the landlord.
This is an important point. One should critically consider whether adhesive solutions are truly secure enough, especially for large PAX wardrobes that are heavy and can tip over. For example, even good adhesive strips can fail under load after weeks or months, posing risks that could result in damage or injury in the worst case.
Additionally, it should be kept in mind that tenancy law and insurance claims often do not favor tenants who fix furniture without permission and proper professional fastening.
Therefore, I recommend focusing on tension rod systems as the safest and also landlord-acceptable option, and contacting the property management in advance if there are any uncertainties.
Furthermore:
- A lower center of gravity increases stability
- Furniture connectors are a simple improvement when using multiple cabinets
The discussion should thus also include legal and safety aspects—not just practical implementation.
