ᐅ How can IKEA HEMNES be used as a basis for a customized shelving system?
Created on: 6 Mar 2020 08:37
karlko
I am currently considering using the IKEA Hemnes shelving unit as a base for a custom shelving system. I am particularly interested in how the existing modules and components can be combined or expanded to create a tailor-made and functional system that goes beyond simple use.
I am looking into aspects such as stability, adaptability, expansion options, and especially whether the system integrates well with other IKEA elements or custom-built components.
What experiences do you have with Hemnes as a foundation for custom shelving systems? Are there any tips, proven additions, or specific assembly methods worth knowing to get the most out of the system without compromising stability or design?
I look forward to an engaging discussion!
Here is a brief guide with some tips for using IKEA Hemnes as a basis for your shelving system:
1. Planning: Measure your installation area precisely and design the shelving system according to the available room dimensions.
2. Selecting modules: Combine open shelves, drawers, and closed doors to create a good balance between visibility and storage space.
3. Connection: For larger shelving arrangements, connect individual units from the back using sturdy metal brackets to ensure stability.
4. Wall mounting: Always secure the entire system to the wall to prevent tipping.
5. Material additions: Plan to use solid wood or high-quality MDF for custom shelves or additional components to maintain the Hemnes appearance.
Common mistakes:
- Neglecting wall mounting, which can quickly become dangerous.
- Overloading individual shelves without distributing the weight.
Following this approach will give you a solid foundation. Feel free to ask if you have any questions!
Common mistakes:
liste schrieb:
For a layperson, this can be a barrier that many do not want to overcome.This is an important point that I would like to highlight: Those with less DIY experience should focus on simple extensions, such as adding more HEMNES modules without custom modifications.
However, smaller alterations like using shelf brackets for additional shelves or replacing feet with adjustable ones are also quite manageable.
karlko schrieb:
What experiences do you have with HEMNES as a basis for custom shelving systems? Are there tips, proven additions, or special installation methods one should know to get the most out of the system without compromising stability or design?For stability, I recommend securing all modules to the wall whenever possible. Using screws instead of nails is essential. Also, be careful not to remove the back panels, as they significantly contribute to stability.
If you want some convenience during modifications, long screws and brackets that can be installed invisibly in corners help maintain the appearance. Regarding surfaces, try to use only HEMNES wood or color-matched pine wood where possible to achieve a uniform look.
In summary: Stability through wall mounting and back panels, modularity by combining various HEMNES elements, and for finer details, small DIY adjustments—this is the best foundation for a custom shelving system based on HEMNES.
