ᐅ Which screw connections in IKEA Hemnes furniture are most prone to issues?
Created on: 9 Apr 2015 18:12
Sisi47
Sisi47
9 Apr 2015 18:12
Hello everyone, some time ago I put together a few pieces of furniture from the IKEA Hemnes series, but now I am a bit uncertain about the screw connections. My specific question is: Which screw connections or particular types of joints in the Hemnes furniture are especially prone to issues such as loosening, material damage, or loss of stability? For example, I mean the connection of the cabinet doors or the attachment of shelves to the side panels. I am especially interested in long-term experiences and advice on where to be particularly careful during assembly or everyday use to keep the furniture as durable and stable as possible.
nikian
9 Apr 2015 18:47
Hello Sisi47, your question is really well thought out, which makes it easier to give an accurate answer. With Hemnes furniture, it is indeed the case that the connections, especially those made with dowels and expansion screws that join the side panels to the back panels, can be vulnerable. After prolonged use or frequent movement (for example, when opening and closing doors), these screws often loosen because they only grip into particleboard, which can deform over time. This is often noticeable through wobbly constructions or creaking sounds. Therefore, I recommend occasionally tightening these connections, but carefully to avoid damaging the particleboard. Another point concerns the screws on the inside used for drawer slides: here, small metal brackets are installed and fixed with tiny screws, which can also tear out under high load.
sonrickey
9 Apr 2015 19:05
Oh, great question! The issue of vulnerable screw joints with Hemnes furniture is really interesting! 😄 From my experience, the connections on the back panels tend to be especially problematic. These are often secured only with thin nails or small screws, and if you move the piece of furniture, you quickly notice the back panel becoming loose. The same applies to the door connections where the hinges are attached. You shouldn’t overtighten the screws there, or the particle board can look like it’s been sun-damaged 😉. So, it’s better to check regularly to make sure nothing is wobbly or squeaky.
Katau
9 Apr 2015 19:33
Hello everyone! I agree with the previous posts and would like to add that the Hemnes models often use what is called a dowel or wooden peg type combined with expansion plugs. These connections can sometimes be prone to tearing under stress due to the material used (usually particleboard with a veneer). The areas where heavier shelves or large tabletops are attached are particularly critical. I recommend being careful not to overtighten the screws during assembly. Additionally, applying some wood glue into the dowel holes before screwing can improve stability. Long-term experience has shown that this measure often prevents issues with loosening.
jakob70
9 Apr 2015 20:01
Brief and to the point: The connection of doors to the side panels via hinges is often vulnerable because the screws can easily pull out of the particle board. For heavier Hemnes furniture, an additional small bracket can be installed for increased stability.
Sisi47
10 Apr 2015 07:45
nikian schrieb:
especially the connection through the so-called dowels and expansion screws, which join the side panels to the back panels, can be prone to issues
Thank you for this note, nikian! I am interested to know if you can recommend proven methods or tools to properly handle these dowel and screw connections. Do you use specific screwdrivers or pre-tension the screws? And do you have any advice on regular retightening: how often and how carefully should this be done to avoid damaging the chipboard?
