ᐅ How can IKEA Hemnes furniture be modified in rental homes in a reversible way?
Created on: 17 Dec 2024 08:14
svenleo
I’m currently exploring how to modify IKEA Hemnes furniture in rental apartments in a way that is reversible, causing no permanent damage or obvious marks when moving out. I’m especially interested in methods, tools, or materials that can enhance, personalize, or expand the functionality of the furniture without necessarily drilling, gluing, or making irreversible changes.
I’m not only looking for practical tips but also for advice on tenant-friendly modifications—such as which adhesives are best suited, how to cleverly avoid screws, or whether there are special reversible fastening systems for wood or MDF furniture.
Perhaps there are also creative ideas on how to create more storage or change the appearance of Hemnes furniture without damaging the original structure.
I would appreciate it if you could share your experiences, ideas, and instructions here!
When making reversible modifications, I always find it important to focus on stability and functionality. For Hemnes, for example, I recommend:
- Replacing screws through existing drill holes, avoiding drilling new holes
- Attaching hooks with removable adhesive tape
- To protect the finish, use felt or rubber pads under supports to prevent surface damage
A nice DIY idea is lightweight clamp rails that can be attached to shelves without screws. These allow you to hang curtains, tarps, or baskets without damaging the wood.
blapau schrieb:
A great DIY project is lightweight clamp rails that can be attached to shelves without screws.I also really like that, especially when drilling is not allowed. At the beginning of my rental period, I was quite uncertain about what was actually permitted. A solution like this reduces a lot of stress because it remains adjustable at any time.
I’d like to elaborate further:
The Hemnes furniture is generally sturdy, but due to the laminated or coated surfaces, it is not completely resistant to mechanical or chemical stress. Therefore, for reversible modifications, I would recommend:
- Using special mounting films or double-sided adhesive tapes that can be removed without leaving residues
- Avoiding the installation of heavy loads on areas secured with adhesive methods
- Using removable fittings with magnets, for example, small self-adhesive magnetic pads on the back
- For lighting or technical extensions, using cable ties that can be removed gently without leaving marks
I would also consider how reversible elements can make use of existing recesses or gaps in the furniture, such as hanging components in shelves or drawers.
One drawback of reversible adhesive techniques is sometimes their limited durability. Do you have any experience with how long these fixings last under normal use?
Palenar schrieb:
One downside of reversible adhesive methods can sometimes be limited durability.That’s true, and that’s why I always pay attention to these points:
- The surface must be free of dust and grease
- The ambient temperature during application should ideally be room temperature
- Apply light pressure and allow time for curing
Additionally: rubberized or painted surfaces can reduce adhesion. That’s why I like to use adhesive tapes specially designed for wood/surfaces on the Hemnes furniture. This way, the adhesive pads can be used for several months.
Those who carefully use moisturizing care products also protect the surface further.
