Hello everyone, I recently bought an IKEA Hemnes piece of furniture and want to repair it as sustainably as possible if it gets minor damage or wears out. I am especially interested in how to handle common issues like scratches, loose joints, or broken wooden parts without having to order replacement parts or replace the entire piece.
Are there proven methods, tools, or materials that work particularly well for these repairs?
Also, what about surface treatment – is it possible to sand the Hemnes wood yourself and then refinish it with paint or oil?
In short: How can IKEA Hemnes furniture be sustainably and long-term maintained or repaired by yourself to avoid premature disposal? Thanks for all tips and ideas!
Matthewt48 schrieb:
For broken wood parts, epoxy wood glue can help, but the best solution is full stabilization with appropriate wooden dowels.Hello, thanks for this tip! Could you please explain in more detail how the stabilization with wooden dowels works in such cases? Do I need any special tools or specific dowel sizes for this?
Also, is there anything I should definitely avoid when sanding and re-oiling to prevent the Hemnes wood from becoming unsightly or unstable?
For broken parts, first apply epoxy adhesive to the fracture surfaces and press them together. Nails or small screws can help to secure the joint additionally.
Dowels are useful when creating strong connections: drill holes on both sides (matching the dowel size), insert dowels with glue, and then press together. It is important to align the holes precisely.
When sanding, it is better to make several fine passes and finish with very fine sandpaper to avoid roughening the surface.
Here is a more detailed workflow for using wooden dowels on broken Hemnes parts:
- Choose dowels that match the thickness of the wood pieces (usually 6-8 mm (1/4-5/16 inch)).
- Mark the drilling points precisely along the break line.
- Use a drill with a depth stop to ensure consistent hole depths.
- Apply wood glue to the dowels and into the holes.
- Join the parts and clamp them with screw clamps until fully dry.
Common mistake: Inaccurate drilling can cause the joint to be weak or the parts to warp. Pay close attention to this.
Regarding surfaces: After sanding, the wood absorbs more oil, so it’s better to apply thin layers and work them in several times rather than applying it all at once. Let each layer dry before applying the next one.
For sustainable repairs, you should also consider using products with low emissions—such as beeswax or natural oils for the surfaces. These protect the wood well and are better for indoor environments.
If the piece of furniture is used frequently, make sure to regularly tighten screws after the repair to prevent wobbling.
And if you want to try something new: there are even special furniture repair kits for IKEA that include screws, dowels, and filler. This way, you can handle everything yourself with precision.
Matthewt4826 Dec 2023 09:02LILUJON schrieb:
Can you explain in more detail how stabilization with wooden dowels works in such cases?The wooden dowels act as strong connection points that mechanically reinforce the break area. The appropriate dowel size depends on the material thickness – usually 6 mm (1/4 inch) for Hemnes.
LILUJON schrieb:
Is there anything I should avoid when sanding and applying oil?Avoid using very coarse sandpaper (e.g., below 180 grit) on lacquered surfaces, as this can cause more harm than good. Also, never apply oil or finish directly on unprepared surfaces – always make sure they are thoroughly dust-free first.
When working with oil, it’s better to apply several thin layers rather than one thick one. Too much oil can remain sticky or dry unevenly.
