ᐅ How can I add ventilation to IKEA Metod cabinets after installation?
Created on: 7 Sep 2023 08:13
Rufa1
Rufa1
7 Sep 2023 08:13
Some time ago, I installed IKEA Metod kitchen cabinets, but after using them for a while, I noticed that the ventilation of the cabinets is rather poor. Especially when you combine deeper cabinets with appliances (like dishwashers or ovens) or simply use the storage space, moisture buildup or odors can occur.
Therefore, my question to the community is: How can I effectively ventilate my already installed IKEA Metod cabinets without having to completely dismantle them?
I am thinking of solutions that are either technically feasible or as inconspicuous as possible. Are there, for example, prefabricated vents, ventilation grilles, or methods you would recommend?
Thanks in advance for your tips and experiences.
Wesley
7 Sep 2023 09:46
Hey Rufa1,
great topic you’re bringing up! IKEA Metod cabinets are really nice, but the ventilation is definitely not their strong point – anyone who’s dealt with damp air inside one knows what I mean. 🍃
From my experience: a simple trick is to add small ventilation slots or grills at the top and bottom. This allows continuous air circulation and prevents moisture build-up. Sure, it looks a bit DIY, but with subtle paint or matching grill covers it hardly stands out. It’s important to also allow air to escape to the outside.
Alternatively, you could place small battery-powered fans inside if you’re comfortable with a bit more tech.
Good luck ventilating your Metod treasures! 😉
LOGEMIN
7 Sep 2023 11:12
to address the question of how to add ventilation to IKEA Metod cabinets after installation, I would like to suggest a structured approach:
- First, measure the cabinet and decide where a ventilation opening would make the most sense (e.g., at the top and bottom).
- Next, you can purchase ventilation grilles to install on the back panel or the side panels – make sure to pay attention to the dimensions and material to ensure stability.
- For those who prefer a discreet solution, small ventilation flaps can be integrated into the base drawer or the plinth.
- Be careful during installation: drilling and cutouts must be done precisely to avoid compromising the cabinet’s stability.
Summary: A combination of ventilation at the top and bottom, for example with grilles, is usually sufficient. Small electric fans are possible but often unnecessary.
If anyone wants more details on implementation, I’m happy to provide them.
daalessio
7 Sep 2023 12:47
One important point I would like to add: Metod cabinets often have a thin hardboard back panel that allows very little air to pass through. To improve ventilation, it is advisable to create one or more openings in the back panel and install suitable vents.
Additionally, it is recommended to ensure that air can circulate internally as well – meaning individual compartments should not be completely sealed off from each other, otherwise the air will still become trapped.
I also suggest not drilling openings that are too large in order to maintain stability. Leaving gaps at the connection to the floor or base area can further enhance air exchange.
U
uslis47
7 Sep 2023 13:54
Hello Rufa1 and everyone else,
I hope I can contribute a bit more to complete this topic. Especially with kitchen cabinets like Metod, which are often built closely together, ventilation is crucial to prevent moisture damage.
It often helps to design the ventilation so that cold air can enter at the bottom and warm air can escape at the top—the classic principle of natural convection. For this:
- Open the underside of the plinth in small intervals or install ventilation grills (for example, in the plinth strip).
- The top edge of the cabinet can have an air outlet.
- If appliances are installed, make sure their ventilation slots are not blocked.
Wesley schrieb:
A simple trick is to install small ventilation slots or grills both at the bottom and top.
This is a good approach, especially if you don’t want to retrofit electronics.
Best regards!
gadalu
7 Sep 2023 15:08
To add to my previous comments: When retrofitting ventilation for IKEA Metod cabinets, it is essential to avoid moisture buildup. Air circulation alone is only effective if the airflow is not obstructed.
Here are some tips:
- Leaving the toe kicks open or fitting them with ventilation grilles increases airflow from below.
- The back panels can be modified with targeted elongated holes or square cutouts fitted with grilles. The size is important; typical openings range between 80–150 cm² (12–23 in²) in total.
- Avoid installing solid internal dividers to allow air to circulate inside.
- Door seals can sometimes be replaced with ventilation strips if it suits the appearance.
Electric ventilators are usually unnecessary and tend to add complexity and noise. Therefore, maximizing passive ventilation is recommended.
