ᐅ How can I use Ikea PLATSA shelving units in a small bathroom?
Created on: 1 Jul 2023 08:23
Milesu
Hello everyone, I am currently planning to redesign my small bathroom and am considering how to best use the Ikea Platsa shelving units. The bathroom is no larger than 3 square meters (32 square feet) and has narrow spaces, but I urgently need more storage for towels, cleaning supplies, and some toiletries. I am especially interested in how to arrange the modules most efficiently, whether wall mounting makes sense, and what options exist to keep the shelves durable and resistant in the often humid bathroom environment. Additionally, I wonder if there are any specific tips for making the most of the limited space without making the bathroom feel too cramped. Has anyone had experience with PLATSA in the bathroom or knows clever layout ideas? I appreciate any input!
Tevin
2 Jul 2023 07:15
Hello everyone, I would like to contribute as I recently equipped a small bathroom with Platsa. My experience confirms that the installation definitely needs to be solid and flush with the wall. I installed my shelves about 30 cm (12 inches) above the floor, which not only makes cleaning easier but also helps reduce moisture issues.
Regarding moisture: I used a moisture-resistant lacquer spray that can be applied to wooden surfaces to protect the material. It is also essential to ventilate well after every shower to prevent heat buildup.
It is also very important not to place the shelves directly next to the shower enclosure or bathtub. For towels, I chose open compartments because air can circulate well there and the items dry faster.
If you like, I can also provide more detailed information about the construction and maintenance.
pikin
2 Jul 2023 08:43
My recommendation is based on an objective and practical assessment: PLATSA is generally suitable as a storage solution for bathrooms, provided that precise measurements and a thorough room analysis are conducted beforehand. Furniture exposed to moisture should have treated surfaces, with either paint coatings or laminates being advisable.
Installation must be on load-bearing walls using appropriate fixing materials. The system offers modular options that are easy to customize, especially through the selection of narrow module widths.
When planning, it should be considered that closed storage spaces offer better protection against moisture, while open areas allow for vapor ventilation. Therefore, a combination of both is sensible and optimal for small bathrooms with controlled ventilation.
Kenon70
2 Jul 2023 10:00
PLATSA is suitable for small bathrooms if you mount the shelves on the wall and protect them from moisture. Use tall, narrow units and combine open and closed storage. A narrow cabinet often fits well above the toilet or washing machine. Be sure to keep a safe distance from splash water areas.
bapar
3 Jul 2023 09:37
Danial schrieb:
Are there any studies or user experiences on how much the PLATSA furniture is actually damaged by moisture?
Unfortunately, there are no official long-term studies from Ikea regarding the moisture resistance of the PLATSA systems in bathrooms. However, many user reports suggest that the units can last several years if there is sufficient ventilation and proper protection. The key factor is ensuring that no standing moisture remains on the components, which can be prevented by correct installation and protective measures.
Tevin schrieb:
I used a moisture-resistant spray lacquer that can be applied to wooden surfaces to protect the material.
That is a very good tip, and I fully agree. Additionally, it is advisable to thoroughly seal all edges, especially the cut edges of particleboard, as these are particularly vulnerable.
I’m also interested in how you manage ventilation in your bathroom. Do you use electric fans or mainly natural ventilation? This has a significant impact on durability.
Milesu
3 Jul 2023 11:22
bapar schrieb:
I’m also curious how you handle ventilation in your bathroom? Do you use electric fans or rely more on natural ventilation?
Thanks to everyone for the detailed suggestions! My bathroom has a small window that is opened daily, and additionally an exhaust system that runs occasionally when the fan is switched on. I plan to install shelves about 20 cm (8 inches) above the floor so I can clean underneath them.
I’m still undecided between open shelves for frequently used towels and closed units for cleaning supplies. The idea of using water-resistant paint sounds very sensible.
Could you also tell me if there are any stability issues when stacking multiple modules? I’m concerned that moisture might eventually cause warping.
