ᐅ How can I secure Ikea BESTA units in the attic against drafts?
Created on: 18 Oct 2019 20:17
Nio42
Nio42
18 Oct 2019 20:17
I have an Ikea Besta unit in my attic room that I would like to better protect against drafts. The furniture is placed directly against a sloped ceiling, where cool air often comes in, especially noticeable during autumn and winter. By now, the draft is strong enough that not only dust is blown onto the furniture edge, but it also affects the items stored there.
I am therefore looking for practical solutions to protect or seal the Besta components against drafts without having to move them completely or make major changes to the furniture. I am also considering measures that block both moisture and cold air but do not completely restrict air circulation in the room.
Has anyone had experience with draft protection specifically for Ikea Besta units in attic rooms? What types of seals, sealing methods, or other tricks would you recommend? Are there any special adjustments for the typical gaps between Besta and sloped ceilings?
I would appreciate any tips!
RAGUGI
18 Oct 2019 21:02
I would recommend flexible foam sealing tapes that can be applied along the edges. They are inexpensive, easy to install, and noticeably reduce drafts. It is important that they are not too thick so the doors can still close properly.
Alternatively, you can use thin rubber sealing profiles, which last longer and are a bit more discreet.
miAlessio
19 Oct 2019 07:48
Hello Nio42,
I can understand your situation well, as drafts can be a real challenge, especially in the attic.
Here are my recommendations in several steps:
- First, you should identify the main source of the draft, specifically the areas on the sloped ceiling where cold air enters. These are often small gaps or uninsulated window sections directly above or beside the BESTA unit.
- For direct protection of the BESTA furniture, foam weatherstripping is ideal; it is easy to cut and self-adhesive. Make sure to choose products with good weather resistance to prevent them from becoming brittle.
- If air is coming in underneath or between the furniture, you can install self-adhesive brush seals on the baseboards. These prevent cold air from entering without damaging the floor.
- Additionally, I recommend sealing the joints between the furniture and the wall with foam rubber strips or sealant to eliminate any small gaps.
- Be sure to use breathable materials to avoid mold growth and moisture problems near the sloped ceiling.
- Finally, improving the insulation or sealing the walls and windows in the attic would be useful, as this reduces overall air movement and provides better protection for the furniture.
Hope this helps!
Foster63
19 Oct 2019 22:31
miAlessio schrieb:
If air drafts under or between the furniture, you can apply self-adhesive brush seals to the baseboards.
I would support this suggestion, especially since brush seals are a sustainable way to effectively reduce drafts without much effort.
Additionally, I would recommend checking the condition of the floor around the BESTA unit in the attic. Small unevenness or missing baseboards often cause drafts, especially when the furniture is placed directly against the sloping ceiling.
It is worth using suitable skirting boards or door seals that do not cause issues with air circulation. You should choose materials that do not retain moisture to avoid damage to the furniture surface.
Finally, a note: air movement in the attic is generally higher than in the rest of the house, so a combination of sealing the furniture and structural measures is usually the best approach.
