ᐅ How can I safely move Ikea Metod cabinets without causing damage during a relocation?
Created on: 21 Jul 2024 09:17
flonaI am planning a move soon and have some Ikea Metod kitchen cabinets that are installed both in the kitchen and the adjacent dining area. My question is quite specific: How can I disassemble, pack, and transport these Metod cabinets in a way that minimizes any damage to the cabinet panels, doors, or fittings? Are there any special tips for dismantling, recommended packing materials, or transport methods that have proven particularly effective based on experience with Metod? It is important to me to be able to reassemble the furniture as completely and damage-free as possible at the new location. I appreciate any advice that can make this process more efficient and safer.
It’s great that you’re asking about how to transport the Metod cabinet components with minimal damage—these units can be quite vulnerable if handled incorrectly.
First, regarding disassembly: Metod cabinets are usually assembled using cam locks and dowels. To avoid damage, you should
- remove all doors and drawer fronts,
- carefully unscrew the fasteners using a cordless screwdriver or a Phillips screwdriver,
- and then detach the modules from the wall.
Make sure to carefully document which screw goes where, as Metod uses many different lengths.
The main risk during transport is scratching and bending of the case parts. Therefore, you should
- wrap each piece thoroughly in bubble wrap (pay special attention to protecting the edges),
- ideally place thin cardboard between the door fronts and the cases,
- and transport the parts upright.
I also recommend packing hinges and fittings in small, labeled bags to make reassembly easier. Use tall, sturdy boxes or furniture blankets as a protective base.
How many cabinets do you need to transport in total, and what are the dimensions of the largest modules? Maybe I can offer more specific advice.
A structured approach helps ensure the safe and damage-free transport of Ikea Metod cabinets:
- Disassembly: Make sure all screws are completely removed, especially the fasteners connecting the carcass and the back panel – back panels are often just slotted in and should also be carefully detached.
- Packaging: Special furniture wrap is recommended for protecting sensitive surfaces, as it is both non-slip and protective. Bubble wrap can be used additionally but may cause slipping if not applied properly.
- Transport: Avoid laying the cabinets on their sides, as this can cause the corners of the carcasses to break. Instead, keep the parts upright and secure them with spacers in between.
It is also advisable to use new screws during reassembly and check any existing dowels for damage, as they can deform during transport. Replacement dowels can be ordered cheaply from Ikea.
With this combination of disassembly, high-quality protective materials, and carefully planned transport, damage can be kept to a minimum.
Palenar schrieb:
How many cabinets do you need to transport in total, and what are the dimensions of the largest modules? Maybe I can help you more specifically.Thank you for the detailed information, Palenar. In total, there are 6 Metod cabinets: three base cabinets each 60 cm (24 inches) wide and three wall cabinets, two measuring 80 cm (31.5 inches) wide and one 60 cm (24 inches) wide. The height of the base cabinets is 80 cm (31.5 inches), and the wall cabinets are about 60 cm (24 inches) high. In terms of weight, I estimate the base cabinets to be around 40 kg (88 lbs), while the wall cabinets are lighter.
I assume the weight and size clearly rule out simply tipping them over and loading them into the van? Does anyone have experience with the best way to load the cabinets into the vehicle with two or three people, without them rubbing against each other or getting damaged? And should the doors and side panels perhaps be transported separately?
I want to avoid any scratches or dents happening during loading or transit.
I support the points mentioned so far and would like to add from my own moving experience: It is important to fully disassemble the cabinets into their individual parts (carcass, doors, shelves) and then pack each piece separately. After that, I always used Whatman paper or special furniture blankets to further cushion every surface.
For protection when loading into the vehicle, sturdy straps or tie-downs help secure the parts upright in the cargo area. Make sure that no direct pressure is applied to the surfaces. The individual cabinet parts should ideally be transported separately – thick padding or blankets should be placed between them to prevent rubbing or pressure marks.
If the doors are placed near the carcass parts, always use cardboard or felt as padding in between. It is also helpful to cover the hinges with protective caps so that no protruding metal parts come into contact with the cabinet fronts.
If anyone has specific questions about disassembly or the proper sorting of small parts, I am happy to assist.
