ᐅ How can I retrofit IKEA PAX wardrobes with soft-close functionality?
Created on: 11 Mar 2022 08:42
MARDAVUT48
Some time ago I bought a wardrobe from Ikea, the PAX model. The sliding doors work well overall, but I miss a soft-close function on the standard hinged doors that gently slows the closing. My wardrobe currently has no built-in soft-close mechanism, and I would like to know if there are practical options to retrofit a soft-close feature on the PAX doors themselves. I am particularly interested in solutions that can be implemented with little effort and do not require extensive modification of the entire wardrobe. Are there specific additional fittings, compatible dampers, or other approaches that can be easily installed afterward? I would be very grateful for any experiences or tips. Thank you!
MARDAVUT48
11 Mar 2022 15:10
GALEO4 schrieb:
I think the whole soft-close hype with PAX is a bit overrated.
I understand that, but especially with small children or in a household where you often store things in the cabinet, the soft-close feature is practical to avoid loud noises and accidental slamming. For me, it definitely improves everyday usability.
Thanks for the food for thought—maybe I can live with that and focus more on smooth operation.
Farmo
12 Mar 2022 08:16
External dampers can be installed quickly if you do not want to replace the hinges. However, soft-close hinges are better suited for heavy doors. For Pax, it is best to choose matching hinges and replace them directly.
Ixfu2
12 Mar 2022 09:03
Soft-close hinges usually fit plug-and-play with PAX if they are clip-on. Simply remove the old ones and install the new soft-close hinges. Pay attention to the door's weight class.
KAMERON
12 Mar 2022 10:42
Additionally, it is recommended to check the exact model designation and load capacity before purchasing soft-close hinges to ensure long-term, trouble-free operation. Cheap imports without standardization can cause problems.
Those who value a professional solution should choose reputable brands, even if they are somewhat more expensive.
