ᐅ How can I retrofit IKEA Metod drawers with soft-close mechanisms?
Created on: 25 Mar 2023 14:23
canploHello everyone, I have a fairly specific question and hope to get the right input here: How can I retrofit soft-close functionality to my already installed IKEA Metod drawers?
I’m particularly interested in the existing drawer modules that were delivered without soft-close, but I want to add the comfortable damped closing feature afterwards. Are there suitable and easy-to-install retrofit kits available, or do I need to rely on special original IKEA replacement parts?
I’m especially curious about the mechanical requirements, for example whether the existing fittings (drawer slides) are compatible with soft-close technology or if I need completely new slides. Also, tips on proper installation and tools to avoid damaging the drawers would be very helpful.
If anyone has experience with third-party solutions or IKEA’s own upgrades, I would really appreciate hearing your feedback. Thanks in advance!
warrenka5725 Mar 2023 15:47Hey canplo, your concern is completely understandable, as the difference with soft-close is really noticeable and makes daily use much more pleasant.
A while ago, I also retrofitted my Metod drawers without soft-close, and at first, I wasn’t sure if I needed to replace the entire original drawer runners. After thorough research, I found out that IKEA actually offers retrofit kits that can be mounted onto the existing runners.
Of course, installation requires some patience and careful work—I even bought screwdrivers with magnetic tips to make screwing easier in the tight drawer slides.
If you need help with the process, I’m happy to share a brief guide from my experience.
I think it’s great that you’re not just accepting the cosmetic flaws and are actually looking for a solution. This will surely motivate others here to upgrade their drawers as well.
warrenka57 schrieb:
IKEA actually offers retrofit kits that can generally be mounted onto the existing rails.That is basically correct, but I would like to go into more detail, especially since the topic of soft-close in Metod drawers is technically a bit more complex.
The relevant soft-close mechanisms at IKEA mostly refer to the so-called “full-extension” drawers with the integrated damper. These are specific to each drawer width and are not simply universally retrofittable.
- If your drawers currently have metal full-extension runners without damping, IKEA offers only limited retrofit options. Often, the entire runner needs to be replaced because the damper is firmly built into the rail.
- Third-party suppliers generally offer soft-close adapters that can be clipped or screwed into the existing runner. I advise caution here, as compatibility strongly depends on the model year and drawer type.
- It is also important to pay close attention to the installation space, as some soft-close adapters require more room and can cause the drawer to jam or make it harder to open.
Before purchasing, it is best to accurately measure the exact product number of your Metod runners and compare it with the specifications of the soft-close kit.
Also: Is it possible for you to remove the drawers? For many tasks, this is really recommended to allow precise installation without pressure.
If you like, you can post the runner numbers here so we can better check compatibility.
To complement the previous explanations, I would like to suggest a structured approach for efficiently retrofitting soft-close mechanisms on Metod drawers:
- Identify the drawer type and the type of extension mechanism installed (full extension, partial extension, rail system).
- Check whether the existing rail is an IKEA soft-close version or if a complete replacement is necessary. This can usually be determined by removing the drawer.
- If a new purchase is required: order the appropriate soft-close rail sets, which come in various sizes and load capacities.
- Before installation: thoroughly prepare screws, tools, and ideally work at a well-lit workspace.
- Remove the old slides, clean the guide rails and the drawer carcass.
- Install the new soft-close rails: be sure to pay close attention to precise positioning and alignment, as even minor deviations can cause malfunctions.
- After installation and before reinserting the drawer, I often use a spirit level check to ensure the front is aligned straight.
- Then, slide the drawer in and perform several open and close tests to confirm the damping works smoothly and evenly.
If desired, I can also provide tips on alternative damping systems, which can be customized individually but are usually somewhat more complex to install.
bapar schrieb:
Installation of the new soft-close runners: Make sure to pay close attention to precise positioning and alignmentThis is a very important point and is often underestimated. Especially with Metod drawers, any slight misalignment in height or depth during installation can cause malfunctions or cause the drawer to jam.
Regarding retrofitting: I recommend using the original soft-close slides from IKEA, as third-party adapters often do not fit perfectly and may lose stability over time.
Also, make sure that the runners are designed for the specific drawer depth. There are different models for shallow and deeper drawers; checking the installation manual or the product label on the runner will help here.
If the project is more complex, it might be worth considering converting individual drawers to soft-close instead of all at once—this reduces potential sources of errors.
