Hello everyone, I have a question about repairing IKEA Malm furniture when there are cracks. I noticed a noticeable hairline crack on the drawer front of my Malm dresser, which might have been caused by heavy stress or temperature changes. My specific question is: What is the best way to repair these cracks myself without damaging the surface appearance or compromising the drawer’s stability? I would like to know which materials are suitable (for example, special wood glue, filler, or surface varnish), the recommended repair process, and whether it is advisable to disassemble the piece or if the repair can be done entirely from the outside. Additionally, I am interested in how to make such repairs as durable as possible while keeping them visually discreet. Thanks in advance for your expertise!
Galedu schrieb:
Is it a problem if moisture has accumulated under the crack, meaning is drying for several days necessary before gluing?Yes, that is indeed an important point. Moisture in the wood or particleboard can prevent the adhesive from curing properly. So if you suspect moisture is present, you should ideally let the area dry for at least 24-48 hours — preferably at room temperature with good air circulation. Avoid using fan heaters or direct heat, as that could damage the surface laminate.
Galedu schrieb:
Are there any specific products that have proven to be particularly compatible?I especially recommend PU wood glue or two-component repair adhesives for furniture, which remain flexible and have good adhesion. For surface repairs, I have often used repair kits from companies like "Holzprofi" or "IKEA-specific repair kits." Always make sure the product is explicitly suitable for laminated or foil-covered furniture surfaces.
As an alternative to wood filler, you can also try repair wax sticks for furniture, which slightly compensate for unevenness and adhere well to laminate surfaces.
Tevin schrieb:
I particularly recommend PU wood glue or two-component repair adhesives for furniture, as they remain flexible and adhere well.I generally wonder whether these repair methods are truly reliable in the long term. For furniture that is used daily, cracks often indicate material fatigue. While cosmetic fixes are possible, the stability might be permanently compromised.
From this perspective, it’s worth considering whether completely replacing the affected parts could be more sensible and possibly even more cost-effective. My expectation for a repair would be that it restores the original functionality as closely as possible—not just the appearance.
So: How durable are these repairs in practice, especially under mechanical stress on the repaired area? Are there any experiences or insights on this?
CORYGAU schrieb:
I generally wonder whether these repair methods are truly reliable in the long term.I understand where you're coming from. In my case, such a repair held up very well for about 2 years and didn’t crack open again. I also made some minor adjustments using a small wax stick back then, which helps to mask any unevenness.
Of course, in the end, particleboard furniture isn’t made of solid wood but is a compromise. Still, for the price, the repair is a pretty practical solution. And hey, as long as you don’t ignore the cracking issue, you can always do some touch-ups. ?
Long story short: If the cracks come back suddenly, replacing the item is still an option. But trying to fix it is better than throwing it away entirely, right? 😉
