ᐅ How can I repair cracks in Malm furniture?
Created on: 21 Dec 2020 08:17
Galedu
Galedu
21 Dec 2020 08:17
Hello everyone, I have a question about repairing IKEA Malm furniture when there are cracks. I noticed a noticeable hairline crack on the drawer front of my Malm dresser, which might have been caused by heavy stress or temperature changes. My specific question is: What is the best way to repair these cracks myself without damaging the surface appearance or compromising the drawer’s stability? I would like to know which materials are suitable (for example, special wood glue, filler, or surface varnish), the recommended repair process, and whether it is advisable to disassemble the piece or if the repair can be done entirely from the outside. Additionally, I am interested in how to make such repairs as durable as possible while keeping them visually discreet. Thanks in advance for your expertise!
Tevin
21 Dec 2020 09:05
Hello Galedu, that is a very well-formulated question, thank you for the details! Basically, Malm furniture is usually made from particleboard coated with a plastic laminate. This makes repairs somewhat tricky, as the laminate surface is difficult to restore. For cracks that penetrate deeply into the particleboard, I recommend the following process: first, carefully fill the cracks with a special wood or furniture glue – there are also types that can be sanded after drying. After that, you should treat the surface from the outside with a suitable repair kit for plastic surfaces to restore a smooth and visually uniform finish. Disassembling the furniture is usually only worthwhile for very deep or technical damage; for hairline cracks, working from the outside is generally sufficient. It is important to thoroughly clean and degrease the surface before treatment, otherwise the glue will not adhere properly. For the final cosmetic touch-up, small paint pens or repair wax can be used depending on the color of your furniture front. The effort is manageable and the durability quite good if you work carefully. If you like, I can also provide you with specific product recommendations!
KAUDRA62
21 Dec 2020 10:42
Tevin schrieb:
For cracks that penetrate deeply into the chipboard, I recommend the following procedure: First, carefully fill the cracks with a special wood or furniture adhesive – there are also versions that can be sanded after drying.
Exactly, that’s already a really solid starting point! And to be honest: sometimes a bit of patience and a clean application is all it takes. However, I would also suggest applying an appropriate sealant after gluing and sanding to prevent the surface from becoming brittle or cracking again. And hey, a little fun is part of it – maybe a nice way to pass the time during cold winter weather. 😉
Oh, and very important: make sure to let the glue dry thoroughly, that helps avoid disappointment later on. 😉
LOSAR
21 Dec 2020 11:18
Apply wood filler to the crack, smooth it out, sand it after drying, and touch up with a suitable varnish. Important: Clean the surface beforehand.
tolokau
21 Dec 2020 13:47
Galedu, here is a brief and structured summary of how I repair cracks in my Malm furniture.
1. Preparation: Clean the furniture of dust and grease, ideally using isopropanol or denatured alcohol.
2. Adhesion: If the crack is open, carefully fill it with wood or furniture glue. Use a syringe or a fine spatula to apply the glue deeply into the crack.
3. Drying time: Let the glue dry thoroughly for at least 12 hours.
4. Refinishing: Gently sand off any excess glue using fine sandpaper (240 grit) to avoid damaging the laminate surface.
5. Surface repair: If the finish is damaged, apply a touch-up paint pen suitable for white or beige Malm finishes by spraying or brushing it on. For best results, apply several thin layers, allowing each to dry in between.
Important: Disassembling the furniture is only worthwhile if there are structural damages. For purely superficial cracks, the described method is usually sufficient. Finally, a transparent satin clear coat will restore durability to the surface.
If you want, I can also share tips on brands and suppliers.
Galedu
22 Dec 2020 07:23
tolokau schrieb:
1. Preparation: Clean the furniture from dust and grease, ideally with isopropanol or denatured alcohol.
Thank you very much for the detailed instructions. May I ask a quick follow-up: Is it problematic if moisture has accumulated under the crack, meaning, is it necessary to dry it for several days before gluing? And if so, what is the best way to ensure thorough drying without damaging the furniture?
Also, I’m wondering if the adhesives or fillers are really suitable for the thin plastic film on the Malm surface. Are there any specific products that have proven to be particularly compatible?
I’m unsure whether regular wood filler might peel off later.
