ᐅ How can I reinforce IKEA BRIMNES shelves?
Created on: 3 Feb 2024 18:27
Leoemil
Hello everyone, I am currently facing the issue that the shelves of my IKEA Brimnes shelving unit bend under heavier loads. Especially the middle shelves seem to only partially support the weight of books and binders. Therefore, my question is: What is the best way to reinforce the shelves of the IKEA BRIMNES unit to make them sturdier and able to carry heavier loads over longer periods? I have already considered adding extra cross braces or metal reinforcements, but I would like to know which solutions are truly practical without significantly affecting the appearance or functionality of the shelving unit. I would greatly appreciate specific tips, experiences, or recommendations for suitable materials.
Surela
4 Feb 2024 09:47
Leoemil schrieb:
My concern is that too many metal brackets could be visually distracting.
That’s understandable. An alternative solution is to use so-called “invisible” reinforcements, such as thin aluminum or steel profiles mounted underneath, parallel to the shelves. These provide rigidity while remaining discreet. Another elegant option is to cut precise grooves or rebates to insert metal or wooden reinforcements, though this requires some craftsmanship. If you want to avoid visible screw heads, countersunk screws can be used and concealed with wood filler matched to the color.
U
uslis47
4 Feb 2024 11:19
Hello Leoemil, I agree with the recommendation to reduce the load by using central supports. Some people also install narrow wooden strips or metal profiles directly under the shelves, which are either clamped or screwed between the side panels.
Depending on how your Brimnes shelves are constructed, it is also worth checking the screws of the shelves themselves and replacing or tightening them if necessary. Sometimes this alone can help prevent unexpected sagging.
If the visual finish is important to you, I would suggest wooden strips that you can paint to match. Metal strips provide a lot of stability but tend to be more noticeable.
mauka
5 Feb 2024 10:03
Hey Leoemil, it sounds like your shelves are really sagging! I’d also suggest looking for slim metal brackets that you can install smartly—maybe not across the entire shelf, but just at the critical points so they stay out of sight.
Or you can do it like a good DJ: mix wood and metal! Use thicker wooden boards as the base, and “turntables,” meaning metal rods, for reinforcement. This way it stays stable and looks cool.
Maybe try placing the shelf on the floor and see where it bends the most? Reinforcing there makes the most sense and saves materials! 😎
ju_ren
5 Feb 2024 11:47
Installing central supports under the shelves usually helps a lot. Additionally, you can reinforce the panels by attaching wooden strips to the back sides.
Surela
5 Feb 2024 15:26
uslis47 schrieb:
Sometimes that alone helps to prevent unexpected bending.
Exactly, tightening the screws or even replacing them with higher-quality screws of a larger diameter often effectively increases stability.
Additionally, I recommend distributing the load across individual shelves and placing heavy items as close as possible to the side walls. This reduces stress on the overall structure in the middle. For those with advanced DIY skills, recessed metal profiles can also be integrated into the wooden shelves—but that’s more of a professional tip.
