I have several BILLY shelves from IKEA that I would like to reinforce afterward because they start to sag under the weight of my books. My shelf is placed against the wall, and I’m not looking for a complete solution with new boards but rather a way to stabilize the existing shelves as simply and efficiently as possible.
What I’m mainly interested in is: Which materials or methods are best suited to stiffen the shelves? Are there practical tips on how to prevent bending, for example with metal brackets, battens, or similar, without having to disassemble the shelf multiple times?
It is also important for me to know if anyone has experience with how much this helps. I don’t want to do elaborate woodworking, but rather a pragmatic DIY solution that is sturdy and relatively unobtrusive.
Looking forward to your suggestions and explanations!
Hello Eduard51,
I can understand your question well – BILLY shelves are very popular, but the shelves tend to sag under heavy weight. Here is a short guide on how to reinforce your shelves:
1. Material selection: Solid wood battens (e.g., 20 x 30 mm (0.8 x 1.2 inches)) are ideal to attach to the underside of the shelves. They significantly increase stability. Alternatively, metal brackets or steel U-profiles can also help.
2. Procedure:
- Drill holes along the bottom edge of the shelves – be careful not to drill through.
- Screw the wood battens or brackets to the underside. For metal brackets, it is advisable to use ones with short legs (about 5 cm (2 inches)) that you can attach centered.
- For extra security, you can fix small wood battens to the wall behind, on which the shelf rests.
3. Assembly tips:
- Always use suitable wall plugs if the wall is involved.
- Countersunk screws prevent the battens from sticking out.
4. Summary:
With simple wood battens, you do your BILLY a big favor. The boards become more stable, you avoid sagging spots, and the result stays discreet. Less is often more here – better one continuous batten than many small additional pieces.
Hope this helps! If you like, I can provide exact measurements and sources.
2. Procedure:
3. Assembly tips:
4. Summary:
giabau schrieb:
Using simple wooden strips will really help your BILLY.I see it a bit differently. Sure, wooden strips are simple, but do they really provide the stability you expect?
My thought is: BILLY shelves are quite thin and more like particleboard. Even the best strip won’t help much if the material inside is already fatigued.
Why not just replace the shelves with thicker boards? Or attach a second shelf on top of the existing one?
And then mounting with metal? That might be more stable, but it’s also visible. For me, reinforcement should be hardly noticeable; otherwise, I might as well buy a new piece of furniture.
So I think it’s important to consider the limits of the material and not try to fix everything with makeshift solutions.
What do you think?
Muso4 schrieb:
Why not just replace the shelves with thicker boards right away?That is certainly an option, but not always practical. The BILLY shelves are standardized and not easy to replace – matching the side panels and drill holes with the exact right size is rare, and modifying the shelves takes additional time and tools.
Muso4 schrieb:
And what about mounting with metal brackets? That might be sturdier, but it’s also visible.It depends on the execution: there are narrow, flat brackets that can be attached underneath at the very back. These are hardly noticeable once the shelf is in place and the front is open. Alternatively, the metal reinforcement can even be installed inside, for example, if plastic edge strips are removed.
So: yes, the shelves are thin, but adding reinforcements with strips or brackets afterward is very effective and cost-efficient for certain uses. You just need to know how to install them neatly.
If concealment is important, the strips can also be painted to match the color or covered with veneer.
In short: not a cure-all, but a good option if you don’t want to replace the entire piece of furniture right away.
