ᐅ How can I protect Ikea BESTA furniture from wear and tear in a household with pets?
Created on: 26 Feb 2020 10:03
CarlosHello everyone,
I have several Ikea BESTÅ furniture pieces at home, which I really like because of their flexibility and design. However, I have two cats, and I’ve noticed that the furniture is starting to show signs of wear in some areas due to scratches, pet hair, and occasional bumps or rubbing.
My specific question is: How can I effectively protect Ikea BESTÅ furniture from wear and tear in a household with pets? I am especially interested in practical tips to prevent surface scratches and possible ways to protect areas prone to dirt, without affecting the look of the furniture.
Do you have experience with protective films, special coatings, or other materials that can be used? Tips on dealing with cat claws or how to maintain the furniture to minimize damage would also be great.
Thanks in advance for your help.
Carlos schrieb:
How can I effectively protect Ikea BESTÅ furniture from wear and tear in a household with pets? I am especially interested in practical tips to prevent surface scratches and possibly measures to protect dirt-prone areas without affecting the furniture’s appearance.This is a very practical question that needs to be considered somewhat differently depending on the type of use and the pets involved.
Generally, the fronts of the BESTÅ series are made from melamine-coated panels or painted surfaces, which are scratch-sensitive—especially to cat claws. You can basically take the following approach:
- One option is self-adhesive, transparent vinyl or PET films designed specifically for scratch protection on furniture. Make sure they can be removed without leaving residue or discoloration.
- Alternatively, plastic panels or acrylic strips can be attached to particularly vulnerable areas (e.g., edges or fronts near cats). These can be fixed in place using suitable mounting adhesive.
- Corners or tops can be equipped with protective edging made of rubber or plastic, which is slightly padded to also prevent impact damage.
- Regarding surface treatment, I strongly advise against repainting or applying chemical sealants yourself, as melamine surfaces do not absorb these well and this can lead to unsightly results or even peeling.
- For cleaning, use mild detergents to avoid damaging the protective layer.
- For the cat itself, in addition to trimming claws, providing scratching furniture near the furniture helps redirect attention away.
If your furniture has doors with handles, pay extra attention to scratch-prone areas, as cats often like to climb using their claws.
If you can provide more details about how the furniture is used and your cats’ behavior, I can offer more targeted advice.
Carlos schrieb:
Do you have any experience with protective films, special coatings, or other materials that can be used?To protect IKEA BESTÅ furniture from wear caused by pets, I recommend the following practical measures:
- Use self-adhesive, transparent protective films made of PET or vinyl, which offer high scratch resistance. These protect the original surface and are reversible.
- Attach acrylic glass strips or thin plastic panels to particularly exposed areas, such as doors and edges.
- Regular care with mild cleaning agents, avoiding harsh or abrasive products.
- As a preventive measure, equipping the room with cat-friendly scratching boards and furniture near the pieces can reduce stress on the furniture.
- Avoid DIY painting on melamine or plastic surfaces, as these materials are incompatible and such attempts are usually ineffective.
These tips are based on material compatibility and practical application in everyday household use.
I completely understand how frustrating it can be when your favorite furniture gets damaged by pets. We experienced the same with our BESTÅ shelf – especially the cats used it as a climbing frame.
What helped us the most was a lot of patience and understanding for the cats. They need spaces to play with their claws. We set up several cozy corners and scratching boards nearby and created positive experiences there with treats.
In addition, we covered the vulnerable areas with protective films. This wasn’t always completely invisible, but it was the best compromise between protection and appearance. You have to be aware that with pets, 100% preservation is difficult, but with measures like these, the damage can be minimized very well.
What about your cats? Do they often get on the furniture, or do they prefer other spots?
In addition to the previous advice, I recommend paying special attention to mechanical stress when protecting furniture:
- Studies show that scratch-prone furniture suffers the most damage from localized mechanical impacts, such as cat claws. One tip is to apply rubber or silicone strips to edges or handle areas to help absorb and reduce the force.
- Regular cleaning is also beneficial to prevent abrasion caused by hair and dust, which together can contribute to additional micro-scratches.
- Some users have had good experiences with furniture wax or polish designed specifically for melamine-coated surfaces. This makes the surface somewhat more resistant without changing its appearance.
- In conclusion, the key is to combine physical protection with managing pet behavior.
