ᐅ How can I properly level IKEA Metod cabinets on uneven floors?
Created on: 7 Jun 2016 19:37
Sipelu
Sipelu
7 Jun 2016 19:37
Hello everyone, I am currently facing the challenge of leveling my IKEA Metod kitchen cabinets on a rather uneven floor. The irregularities measure several millimeters in some places, which makes assembly quite difficult. My question is: What options are there to level the Metod cabinets on such uneven floors so that they stand stable, do not wobble, and the fronts align neatly in a straight line? Are there any special tools, tips, or technical solutions (e.g., adjustable legs, wooden shims, filler compounds, etc.) that you would recommend? I want to avoid the cabinets looking “crooked” later or the doors not closing properly. Thanks in advance for your advice and experiences!
flope60
7 Jun 2016 20:05
Hello Sipelu,
Regarding your topic about leveling IKEA Metod cabinets on uneven floors, I’m happy to provide a detailed answer, as this is a common challenge during kitchen installations. Basically, you should follow these points:
- First, carefully check the floor and measure the most significant unevenness.
- If possible, create a flat base before assembly, for example with chipboard or MDF boards, which you can adjust as needed.
- IKEA Metod cabinets have adjustable legs. Use these to compensate for height differences of about 3-4 cm (1 to 1.5 inches).
- For larger uneven areas, plastic or rubber pads under the legs are recommended to ensure better stability.
- During assembly, initially screw the cabinets together loosely and then level them with a spirit level before tightening everything firmly.
- It’s also worth trimming or notching the baseboard at the bottom to visually compensate for floor unevenness.
One more tip: if you plan to use leveling compound, make sure it is completely dry before starting assembly. This will prevent later settling or sinking.
Summary: Adjustable legs, solid bases, and careful measuring are key to properly leveling Metod cabinets even on uneven floors. With precise adjustment, doors and fronts can also be perfectly aligned afterwards.
Hope this helps you!
DUUS32
7 Jun 2016 21:12
flope60 schrieb:
Another tip: If you want to work with leveling compound, make sure it is completely dry before you start building.
I can only confirm that. For me, it was quite a stressful moment because I hadn’t allowed enough time. Especially if you place the Metod cabinets on a screed floor that has received leveling compound, you absolutely need to make sure everything is fully dry. Otherwise, your kitchen will end up uneven in the room.
Also, I wanted to say that at the beginning I felt the same way as you – the issue of uneven floors really made me nervous. I can only encourage you: with patience and precise leveling, you can install the cabinets stably. Use the adjustable cabinet feet and really check carefully with a spirit level.
If you notice that some cabinets really wobble, you can, if available, place small washers under the floor screws until it fits. It often takes some careful work, but the result is worth it.
RIDAN
8 Jun 2016 08:44
I recommend fully utilizing the adjustable feet of IKEA Metod. It’s best to roughly align them first, then check with a spirit level and make fine adjustments. If there are significant unevenness, you can use small wooden wedges to secure under the feet. It is important that all cabinets are fixed to each other after alignment to ensure stability.
PERON
8 Jun 2016 12:36
RIDAN schrieb:
I recommend fully using the adjustable feet of IKEA Metod.
Absolutely right! And here’s a little personal tip: if you place the Metod cabinets on slightly uneven floors using the adjustable feet and then see how perfectly the fronts align afterwards, it just feels great 😎. A bit of patience while adjusting really pays off.
Also, I would advise you to carefully fit the baseboards if possible. This way, you can hide unevenness at the bottom and the kitchen appears much more elegant. Nowadays, you can adjust the baseboards by cutting them breathable or sanding them slightly.
So, in the end: lots of tweaking with feet and baseboards and staying calm. It works really well!
