I am planning to repaint my Ikea Metod kitchen cabinets because I find the standard surface too plain and would like to give them a more personal touch. My question is: What is the best way to repaint the Ikea Metod kitchen system afterward to achieve a durable and neat finish?
It is important to me that the surface does not peel or show brush marks later, and that the paint lasts a long time. I understand that the cabinets are mostly made of coated particleboard, and I have read that proper surface preparation and priming are crucial. However, I am missing a clear, structured procedure with recommendations for the best materials and techniques, such as sanding, priming, type of paint, and possibly sealing.
I am also interested in tips on removing the cabinet fronts before painting or whether it is better to completely disassemble the cabinets. Which tools and painting supplies have worked well for you?
I look forward to detailed experiences and recommendations, ideally step by step, so I can approach the project cleanly and successfully.
Hello TOBORYS,
Your project is definitely feasible, but you need to plan the process carefully since the surface of Metod fronts is usually melamine-coated, and painting without proper preparation will not ensure long-lasting durability.
Here is a detailed procedure I recommend:
- First: Remove all fronts and handles to easily access all surfaces. This will allow you to work cleanly.
- Sanding: Use sandpaper with a grit of 180 to 220 to lightly roughen the surface. Avoid sanding too hard to prevent damaging the substrate. The goal is just to break the glossy seal so that the subsequent primer can adhere properly.
- Cleaning: After sanding, completely remove the dust, ideally with a lint-free cloth and denatured alcohol or a specialized cleaning wipe.
- Priming: A bonding primer based on synthetic resin is advisable here, for example a 2-component or acrylic primer suitable for melamine-coated surfaces. This ensures good adhesion between the base and the paint.
- Then let it dry as specified by the product—usually at least 12 hours.
- Painting: You can use acrylic or synthetic resin paint. Short-nap rollers or spray guns are recommended to achieve a smooth finish. Several thin coats are better than a few thick ones.
- Between coats: Lightly sand with very fine sandpaper (grit 400–600) after each paint layer to remove any unevenness.
- Sealing: Optionally, you can apply a clear coat for protection if your colored paint does not provide sufficient durability.
Important: Work in a dust-free, well-ventilated room and ideally at moderate temperature (around 20°C (68°F)). Anything else would be risky for adhesion.
It would also be helpful to know how much wear your fronts already have so any touch-ups can be considered. Feel free to share more details if you like.
Hi TOBORYS!
I think it’s great that you want to give your Metod furniture a fresh look. 😊 If you follow PLOMA’s tips, you can achieve some really cool results. Just a small extra tip: be patient, because multiple layers and sanding in between take time, but it definitely pays off in the end!
Also, if you’re up for it, try spraying the paint with a spray gun or paint sprayer. This creates a particularly smooth and even finish that looks almost professional.
And don’t be afraid of sanding—that’s essential to make sure the new layer sticks well and doesn’t chip off easily. Remember: it’s better to be gentle and thorough than rushed and rough! 😉
Have fun with your project!
PLOMA schrieb:
It would also be helpful to know how heavily your cabinet fronts have been used, so we can consider whether refinishing is necessary. Feel free to provide more details if you like. Thanks in advance for the detailed response! The fronts are about 3 years old, with the usual minor signs of wear (light scratches, some areas with a slightly dull surface) but nothing serious or chipped. My main idea was to fully level them through the sanding process to ensure good adhesion. Do you think in this condition I need to use filler or something similar, or is just sanding enough?
Also, one more question: Does it make sense to treat the edges specifically (since edges on Metod cabinets are often a bit more delicate due to the coating), or is simple sanding sufficient everywhere?
Looking forward to your recommendations, as I want to proceed as professionally as possible.
TOBORYS schrieb:
Does it make sense to treat the edges specially (since edges on Metod are often a bit more delicate due to the coating), or is simple sanding everywhere enough? Metod kitchens often have edges covered with melamine foil or ABS edging. These are durable, but paint adhesion on the edges can be challenging because the surface is smooth and the paint layer becomes thinner around the rounded edges.
My advice:
- Lightly sand the edges as well, but carefully to avoid damaging the material.
- If edges are damaged or worn, special edge fillers or repair putty can be used to even out irregularities.
- After sanding, apply an adhesion primer to the edges too.
This is the only way to ensure an even and long-lasting paint finish in those areas.
Careful preparation of the edges should be considered essential.
