ᐅ How can I customize Ikea Besta units with paint without it peeling?
Created on: 25 Apr 2021 14:23
duncanben
duncanben
25 Apr 2021 14:23
I am considering painting my Ikea Besta shelving unit myself to give it a personalized look. I am wondering about the best way to prepare the surface and which paints and techniques are suitable to ensure the paint lasts and does not start peeling off shortly after application. Specifically, I am interested in which steps are necessary for surface preparation, whether sanding is essential, and what type of paint or finish I should use if I do not want to apply a separate protective topcoat. Has anyone had experience painting the melamine surfaces of the Besta, or any tips on how to improve the durability of the paint?
bapar
25 Apr 2021 15:12
Painting Ikea Besta furniture is challenging, mainly due to the smooth melamine coating, which is not very paint-friendly. Here is a detailed guide on how to proceed:
- First, it is important to thoroughly clean the surface, preferably with a degreasing cleaner, to remove all residues.
- After that, I would recommend mechanical sanding with fine-grit sandpaper (grit 220 to 320) to slightly roughen the surface, which helps the paint adhere better.
- Important: After sanding, remove all dust completely, for example with a damp cloth.
- The best option is to use special bonding primers (also called melamine or plastic primers) designed for preparation on smooth surfaces. Without primer, chipping can occur quickly.
- In terms of paint, I would recommend acrylic or two-component (2K) coatings. Acrylic paints are water-based, easier to apply, but may require an additional protective topcoat.
- If you don’t want an extra protective layer, there are also 2K coatings that serve as a final layer and are very durable.
- Pay attention to drying times and layer thicknesses; otherwise, the paint may not cure properly or could crack.
One question: Do you plan to use the furniture intensively later, for example as a TV stand, or rather as a decorative element? This influences the choice of paint and whether a protective coating is necessary.
NoValentin
25 Apr 2021 17:45
Simply sand the surface, then apply an adhesion primer and paint with acrylic paint. Afterward, apply at least one layer of clear varnish for protection. This will prevent chipping.
tanru
26 Apr 2021 09:37
I’m still looking into this: Are there reliable experiences on how well adhesion primers actually work on melamine? You often read conflicting opinions; some say no paint sticks without chipping, no matter how well you sand or prime. Should one use a special plastic primer instead of a classic adhesion primer, or can this be handled with a good all-purpose primer?
Also, what about alternatives like wrapping? Of course, that’s not painting, but maybe a sensible option that is more durable?
I’m asking because I don’t really want to accept having to work endlessly with extra layers if the result still isn’t perfect.
FRANCISCOP
26 Apr 2021 11:05
To clarify the discussion: The melamine surfaces of the Ikea Besta modules are extremely smooth and have a chemically inactive surface, which makes paint adhesion difficult.
- The key is thorough sanding with fine-grit sandpaper, ideally 320 grit, to enable mechanical adhesion.
- Special resin- or plastic-based primers are recommended, as they are chemically formulated for this type of surface.
- Alternatively, specialized adhesion promoters for plastics can be used.
- Acrylic paints are generally suitable but, without sealing, have lower abrasion resistance, which can lead to flaking.
- Two-component (2K) coatings offer higher durability but are more complex to apply.
Foil covering is a practical alternative that requires no drying time and shows little wear; however, its appearance is limited and it demands precise application.
For optimal durability, I recommend the following process:
- Clean
- Sand
- Apply plastic primer
- Use a 2K coating for color and protection
Note: It is essential to observe the drying and curing times of the 2K coating, at least 24 hours under optimal conditions.
PRA64
27 Apr 2021 08:54
Here is a simple step-by-step guide in case someone like duncanben wants to proceed practically:
1. Cleaning: Thoroughly clean the Besta surface with isopropanol or another grease-dissolving cleaner.
2. Sanding: Lightly sand the surface with 220-320 grit sandpaper. Avoid sanding too aggressively to prevent damaging the material.
3. Remove dust: Wipe off sanding dust with a damp cloth, then use a lint-free cloth to remove any remaining residue.
4. Primer: Apply a plastic or melamine primer thinly with a fine brush or foam roller. It is better to apply several thin coats than one thick coat.
5. Drying time: Wait about 12 hours depending on the product instructions.
6. Paint application: Apply acrylic or 2K paint in thin layers. You can sand lightly between coats with very fine 400 grit sandpaper for a smooth finish.
7. Final step: For extra protection with acrylic paint, seal with clear coat; with 2K paint, this is often included.
Common mistakes include applying paint too thickly, insufficient sanding, or not using a bonding primer. All of these can cause peeling.
One more tip: It’s best to work at 20-25°C (68-77°F) with moderate humidity, as this improves drying and adhesion.
