ᐅ How can I make Billy doors operate smoothly and quietly?
Created on: 30 Jan 2019 17:23
Pauka
Pauka
30 Jan 2019 17:23
Some time ago, I bought the popular Billy bookshelf from IKEA and overall, I am quite satisfied with it. However, I have a problem: the doors are a bit stiff, and when opening and closing, they make quite disturbing noises – creaking, and sometimes even a slight squeaking.
My question is: how can I make the Billy doors operate smoothly and, above all, quietly, without affecting the appearance or having to carry out complicated modifications? Are there any proven methods or materials you would recommend?
I have already oiled the hinges, but that brought little to no improvement. Maybe the issue is with the runners or the door installation.
Thank you in advance for your tips!
Katau
30 Jan 2019 18:46
Hello Pauka,
I’m familiar with this problem and can offer you some tips that I have used several times myself.
First of all, you should check whether the doors are properly aligned – meaning they hang straight and the hinges are securely fastened. Sometimes a slight misalignment is enough to make the doors stiff to operate.
Regarding the noises: creaking and squeaking usually come from dry or dirty hinges. A special silicone spray or a lubricant designed for furniture hinges (not WD-40, which is more of a cleaner and rust remover) often helps here. It’s important to apply the lubricant sparingly and then open and close the door several times so the lubricant spreads evenly.
Additionally, felt or rubber buffers placed between the door leaf and the shelf can help. These not only reduce noise but also cushion impacts, making the doors close more smoothly.
Another possible cause could be slightly damaged plastic guides or tracks on the hinges. You can clean these carefully and, if needed, treat them with some Teflon or silicone spray.
If you want, you could also replace the hinges with higher-quality, soft-close models that are specifically designed for smooth and silent operation. This takes a bit of effort but is worthwhile in the long term.
In summary, I would recommend the following:
1. Properly align the doors and check the hinges
2. Treat the hinges with a special furniture lubricant
3. Install rubber buffers or felt strips
4. Clean the plastic guides and, if necessary, lubricate lightly
If you’re at it, you can also completely remove and clean the door fittings – in most cases, this already solves a large part of the problems.
Good luck! If you want, I can also suggest specific products.
Pauka schrieb:
"The doors are somewhat stiff and make quite disturbing noises when opening and closing – creaking, sometimes even slight squeaking."
That sums it up well – I had exactly the same symptoms.
RIDAN
31 Jan 2019 07:52
Oiling rarely achieves the desired effect. It is better to use silicone spray on plastic parts and hinges. Avoid oils, as they can attract dirt.
Seals or felt strips between the door and shelving help to reduce noise.
Check if the doors are properly aligned to minimize friction.
Good luck!
PRA64
1 Feb 2019 14:37
Hello Pauka and everyone interested,
here is a structured guide on how to make your Billy bookcase doors operate smoothly and quietly – including common mistakes to watch out for.
1. Aligning the doors:
- Open the door and slightly loosen the hinge screws, align the door using a spirit level, and then tighten the screws again. Properly aligned doors generally run more smoothly.
2. Cleaning:
- Sometimes dust or small wood chips/dirt accumulate in the hinges or sliding rails. Painful but often effective: remove the hinges and clean them thoroughly.
3. Lubrication:
- Use only a dry silicone-based lubricant (silicone spray). Avoid oil-based products, as they tend to become sticky.
4. Adding rubber buffers:
- Small rubber buffers between the door and the bookcase frame reduce noise and enable soft closing movements. This is especially beneficial for heavier doors.
5. Check the sliding rails:
- Some Billy versions have sliding rails made of plastic or wood. If these are warped or damaged, they can cause noise. Replace them if necessary or carefully sand them smooth.
6. Alternative hinges:
- If you are willing to invest a bit more, you can buy soft-close hinges that make closing almost silent.
Common mistakes I often see:
- Excessive oil leads to dirt buildup.
- Hinges installed too tight or too loose.
- Buffers completely missing.
I hope this helps! If you need more details, just ask.
Katau schrieb:
"Special silicone spray or lubricant for furniture hinges... often provides good relief here."
I can only confirm that; silicone is almost always the better choice for furniture.
RIDAN schrieb:
"Check if the doors are properly aligned, as this minimizes friction."
Well said.
