ᐅ How can I install IKEA Metod cabinet doors with integrated pull handles?
Created on: 7 Sep 2020 18:37
le_sau43
le_sau43
7 Sep 2020 18:37
Hello everyone, I am currently planning the installation of IKEA Metod kitchen cabinets and am particularly interested in the doors with recessed handles, as they look very appealing and modern. My specific question is: How do I correctly and securely mount these Metod doors with recessed handles onto the cabinets? Specifically, I would like to know if there are any special mounting materials or techniques I should consider for these recessed handle doors, since the handle is not a traditional one.
Do I need special hinges or a different drilling template? And how should I align the doors to ensure an even gap and the correct function of the recessed handle?
Although I have some experience with furniture assembly, I want to be absolutely sure before attaching the doors to achieve perfect appearance and usability. Thanks in advance for any tips and advice!
PRABAU
7 Sep 2020 19:12
The installation of Metod doors with handle recesses basically works like with regular Metod doors. You need the standard Metod hinges that IKEA provides.
It is important to align the door precisely using the hinge adjustment. If you have the handle recesses, make sure the door front sits completely flush, otherwise the recess will appear uneven.
The holes on the doors are pre-drilled, so you do not need a special drilling template for the recess.
Ianlau
8 Sep 2020 10:04
Hello, I would like to add to your question and provide a more detailed guide on how to correctly install Metod doors with recessed handles.
First of all, it is true that doors with recessed handles use the same hinges as regular doors. IKEA usually provides 110° hinges, which you can simply attach to the door and the cabinet frame. The hinge drill holes are pre-made and should fit precisely.
Since you have a recessed handle instead of a grip, it is especially important that the door is aligned accurately. Small misalignments are more noticeable compared to regular handles because the recess acts like a framed opening. Use the adjustment options on the hinges:
- Horizontal adjustment to align gap widths
- Height adjustment to align the door front correctly
- Depth adjustment so the door closure fits perfectly
When installing, make sure the screws are tight but not over-tightened to keep the door in position and avoid warping.
If the doors are not pre-drilled (which is rare), you will need a drilling template for the hinges. The recessed handle itself does not require additional work since it is already pre-assembled.
I also recommend loosely attaching and aligning all doors before final installation to check gaps and the fit of the recesses.
If you have any further questions, feel free to ask!
nanidra
9 Sep 2020 21:46
Ianlau schrieb:
When installing, make sure the screws are tight but not overtightened, so that the door holds its position and does not warp.
This is exactly where many people fail. I often see that people believe the tighter the screws, the more secure the door will be. In fact, the opposite is true, especially with doors that have recessed handles.
The recess demands a certain level of precision because any distortion is immediately noticeable. My advice: tighten the screws just enough so the door doesn’t move, then check again to ensure the recess is truly flush.
Additionally, doors with recessed handles generally allow less room for adjustments on the existing hinge, since the appearance cannot be concealed with external handles. So, you really have to align everything carefully.
You could almost say that doors with recessed handles are better suited for professionals or at least very patient DIYers—not because the installation is more complicated, but because of the high visual standards.
