ᐅ How can I equip an Ikea Pax wardrobe with electrical outlets inside?
Created on: 27 Apr 2018 08:17
U
Usdan45
U
Usdan45
27 Apr 2018 08:17
I plan to modify an Ikea Pax wardrobe to integrate power outlets inside. My main goal is to be able to plug in electronic devices such as electric shavers or chargers for smartphones and tablets directly inside the wardrobe, without visible cables outside. The outlets should be safe and user-friendly to access, ideally positioned so that they are not excessively stressed or damaged when the door is closed, while also ensuring adequate ventilation for any connected devices. Are there established methods or special installation kits suitable for fitting power outlets in a Pax wardrobe? What risks and safety considerations should I be aware of beforehand, especially regarding electrical wiring, circuit protection, and fire safety? I look forward to concrete tips and experiences on the topic “How can I equip Ikea Pax with power outlets inside?”
GIPAPO
27 Apr 2018 09:33
You should use special flat 230V power strips that can be mounted inside the cabinet. Make sure they are compatible with the wall-mounted shelving system. It is important to have approved wiring installed behind the wall or by a professional.
gaubla
27 Apr 2018 11:05
In principle, installing power outlets inside a piece of furniture is technically possible but requires compliance with relevant electrical standards (such as VDE 0100), especially regarding protection against short circuits and overloads. It is recommended to use protected power strips with integrated residual current devices (RCDs) to minimize the risk of electric shocks. Since the interior of a Pax wardrobe usually lacks sufficient ventilation, overheating protection should definitely be considered. An alternative would be to mill openings for outlets in the bottom or back panel of the wardrobe and connect them using appropriate cable ducts to prevent cables from being pinched by door hinges.
BAUEVA
28 Apr 2018 07:21
gaubla schrieb:
One alternative would be to mill recesses for sockets into the cabinet base or back panel and connect them using suitable cable ducts
I consider this method problematic because milling the back panel usually reduces stability and, in the case of furniture made from particleboard like those from Ikea, it is not advisable without additional reinforcements. There is also the risk that moisture or dust could enter the interior. Furthermore, I wonder how practical this is if the cabinet is placed directly against the wall. Has anyone had experience with the long-term stability of this approach? It would also need to be clarified how proper grounding should be ensured when the sockets are located inside the furniture.
LAURE-TA
28 Apr 2018 09:48
I would like to provide a structured guide on how to safely install power outlets inside an Ikea Pax wardrobe:
- Planning: First, determine the exact location for the power outlets. The side panel or the wardrobe floor is recommended, as long as it is easily accessible.
- Cable routing: Wiring should be routed through existing cable channels or secured using special cable clamps. Never run cables over hinges or door frames.
- Selection of outlets: Purchase flat, furniture-certified power outlet modules that include child safety features.
- Installing the outlet: It is advisable to cut a hole using a multitool or hole saw and to fit edge protection strips around the opening to protect the cable insulation.
- Electrical safety: The outlet should be protected by a dedicated residual-current device (RCD / ground-fault circuit interrupter) and may include a smart outlet for monitoring overheating and current.
- Ventilation: Since devices generate heat, it is recommended to install small ventilation slots or an active fan if the devices will be operated continuously.
Please have the electrical work checked by a qualified electrician, especially regarding protection and grounding. Safety comes first.
If anyone has specific questions about tools or detailed procedures, I’m happy to help.
O
ONRONA
28 Apr 2018 14:37
LAURE-TA schrieb:
Electrical safety: The outlet should be protected by a separate residual current device (RCD) and possibly equipped with a smart plug for overheating and current monitoring.
I agree with this but would like to add that using smart plugs does not always provide the necessary protective functions in terms of electrical safety. For example, if the wardrobe is made of particleboard, fire protection becomes a significant concern. The wiring and outlet must be installed in a way that prevents any fire risk in case of a fault. Simply retrofitting without checking the surroundings is risky.
