ᐅ How can Ikea Pax wardrobes be used effectively in the garage?
Created on: 16 Oct 2023 08:23
O
onjodan
Hello everyone, I am currently planning to better organize my garage and am considering using the Ikea Pax cabinets for this purpose. My garage is approximately 5x7 meters (16x23 feet), unheated, and I want to store not only tools and gardening equipment there but also seasonal clothing, accessories for bicycles and cars, as well as a few moving boxes. I am interested in how Pax cabinets can be used effectively in such an environment—especially regarding moisture, stability, and maximizing storage space on a small footprint. What experiences have you had with them? How should the cabinets be modified or supplemented to make them suitable for a garage? Thanks for your advice!
To summarize once again: Using Ikea Pax wardrobes in garage environments is generally possible, but comes with the following requirements – moisture protection through impregnation or protective mats – securing against tipping by attaching to the wall – use of plastic boxes as internal dividers – regular inspection and good ventilation – possible additional equipment with battery-powered LED lights.
These points minimize risks and improve usability. It is advisable to check the mechanical and climatic conditions of the garage before implementation.
Especially if you tend to worry about moisture, proper ventilation of the garage is essential. Also keep in mind that even slight temperature fluctuations in winter can cause condensation issues. Plexiglass has the advantage of keeping cabinets lighter, but be cautious at temperatures around freezing point. I wish you the best of luck with your project.
I would like to add that installing additional rubber buffers under the cabinets is a simple and effective way to prevent moisture from the floor. If you want to store packages of seasonal clothing inside the cabinet outside, it helps to also pack them in breathable fabric bags. The combination of protection and good organization makes using Pax in a garage quite feasible.
Thanks to everyone for the diverse contributions! I will definitely plan for wall mounting, arrange protective mats, and set up regular ventilation. I also find the idea of battery-powered LED strips very practical. If I encounter any issues later on, I will surely get in touch again. Until then, best regards!
