ᐅ How can I equip an Ikea Pax wardrobe with electrical outlets inside?
Created on: 27 Apr 2018 08:17
U
Usdan45
I plan to modify an Ikea Pax wardrobe to integrate power outlets inside. My main goal is to be able to plug in electronic devices such as electric shavers or chargers for smartphones and tablets directly inside the wardrobe, without visible cables outside. The outlets should be safe and user-friendly to access, ideally positioned so that they are not excessively stressed or damaged when the door is closed, while also ensuring adequate ventilation for any connected devices. Are there established methods or special installation kits suitable for fitting power outlets in a Pax wardrobe? What risks and safety considerations should I be aware of beforehand, especially regarding electrical wiring, circuit protection, and fire safety? I look forward to concrete tips and experiences on the topic “How can I equip Ikea Pax with power outlets inside?”
To conclude, I would like to point out the following facts:
- Protective measures according to DIN VDE standards must be strictly followed.
- Make sure to use tested components that are specifically approved for installation in furniture.
- It is also recommended to hire a certified electrical contractor for the installation.
I agree, as the Ikea Pax wardrobe is built on a modular design, and stability is provided by the back panel and side panels. Such modifications should be carefully planned and supported. If in doubt, it is better to install a power strip with a clamp clip inside, which does not require any structural alterations.
BAUEVA schrieb:
I consider this method problematic because milling the back panel usually reduces stability
