ᐅ How can I decorate Ikea PAX doors using self-adhesive films?
Created on: 5 Feb 2023 14:23
Maksym65
Maksym65
5 Feb 2023 14:23
Hello everyone, I’m looking forward to your expertise: I want to decorate my IKEA Pax wardrobe doors with self-adhesive films to give them a more personalized and modern look. I have several questions I’d like to ask you: Which materials work best to ensure good adhesion? How should I prepare the doors so that the film sticks well and no bubbles form? Are there any techniques or tools that make the application easier? And what about the durability over time and possible residue when the film is removed later? Any tips on specific types of films, tools, or experiences with printed designs would also be very helpful. Thanks in advance for your advice!
CARLA
5 Feb 2023 15:07
For preparing the Ikea PAX doors, it is important to thoroughly clean the surface. It is best to use a grease-dissolving cleaner and a lint-free cloth to remove all contaminants. This is the only way to ensure that the film adheres reliably over the long term.
For the films, I recommend a high-quality, self-adhesive PVC film designed specifically for furniture. These are durable and can be removed without leaving residue if needed, which is often not the case with cheaper alternatives.
The following tools are useful for application: a squeegee or plastic spatula to remove bubbles, and a hairdryer or heat gun to make the film more flexible when heated, especially around the edges.
Important: The film should be applied slowly and evenly, from one side to the other, to avoid air pockets. A useful tip is to partially peel off the protective backing at first and then continue applying the film section by section after fixing it in place.
LUISABEL
5 Feb 2023 16:42
CARLA schrieb:
For the films, I recommend a high-quality, self-adhesive PVC film specifically designed for furniture.
I agree with that and would add: When purchasing, be sure to pay attention to the film thickness. Thinner films (<100 µm) can tear or bubble more easily, while medium to thicker films (120–150 µm) make the application and removal significantly more durable.
Furthermore, I recommend checking the film manufacturer’s references in the furniture sector or reading product reviews, as not every so-called furniture film is truly suitable for smooth plastic doors such as those on PAX.
Regarding door preparation, I would add: In addition to cleaning, lightly sanding with very fine sandpaper (around 600 grit) can improve adhesion if the surface is very smooth or lacquered. Remove dust immediately afterward.
Using a fine spray mist of water with a drop of dish soap can help during application by allowing some adjustment and better air release when laying the film and working it with a squeegee.
Jeanbar
6 Feb 2023 10:15
Hello, I would like to add the following: Especially with Ikea PAX doors, the surface is often melamine-coated or lacquered, which can limit the adhesive properties.
Therefore, before applying the film, check whether the film guarantees good adhesion on such surfaces. Otherwise, edges may lift or the film may bubble due to moisture.
Preparation:
- The surface should be room temperature, with no dust residues.
- Perform an adhesion test on a small area using a piece of the chosen film.
Application:
- Always apply slowly, using a squeegee from the center of the film toward the edges.
- Use a heat gun at a low temperature to gently warm the film if needed, to make it more flexible.
Durability and maintenance vary greatly depending on the location (e.g., more moisture in the kitchen). For any residue left when removing the film, I recommend a special solvent to clean off adhesive remains.
Tatovin
7 Feb 2023 07:59
Maksym65 schrieb:
How should I prepare the doors so that the film adheres optimally and no bubbles form?
Clean and degrease thoroughly before applying, then wipe with clear water.
CARLA schrieb:
A squeegee or plastic spatula for removing bubbles, and a hairdryer or heat gun to make the film more flexible if needed
Exactly, a squeegee and hairdryer are very helpful.
One more tip: don’t fully peel off the backing, only partially; this makes adjustments easier.
After applying, simply press out all bubbles again with the squeegee.
