ᐅ How can I customize Ikea Metod kitchen cabinets after installation?
Created on: 21 Sep 2021 08:37
colmankinC
colmankin21 Sep 2021 08:37Hello everyone, I’m interested in how I can customize or upgrade my used IKEA Metod kitchen cabinets afterwards. The cabinets are quite functional and have a classic design, but I would like to give them a more personal touch so they better fit my interior style. Are there any proven methods, such as replacing fronts, adding extra elements, painting, or other modifications that can be done without extensive carpentry skills? I’m mainly looking to gather practical ideas that make the furniture noticeably more appealing without losing its modular character. I look forward to your tips and experiences!
jordanvin21 Sep 2021 10:12Great topic! I had exactly the same issue with my Metod kitchen and thought it was fantastic how much you can do! 😊
What I recommend is starting by replacing or painting the cabinet fronts. There are plenty of DIY guides on sanding the doors and painting them with special kitchen paint – it really gives a fresh look! You can also change the handles, which often looks much more modern and is affordable.
Additionally, open shelving or custom-built shelf units add liveliness to the kitchen and break up the overall look. For example, I attached some wooden crates as shelves in front of the Metod cabinets – it looks amazing!
Don’t forget other details like LED lighting under the wall cabinets, which creates a really cool atmosphere.
Go for it – there’s a lot of potential in there!
I can understand that you want to customize your Metod kitchen. It’s easy to feel overwhelmed because there are so many options, and it’s not always clear what can be done without a lot of effort.
I have made some small changes myself: for example, I used leftover wallpaper or self-adhesive films to decorate the inside of the shelves. This adds a personal touch without altering the furniture itself. It’s amazing how much of a difference that can make!
That’s true, but I found it helpful to test how durable a paint finish is beforehand, especially in the kitchen. Moisture can be a real challenge. That’s why a good paint and possibly a sealant help.
Maybe this will help you decide where to start. In any case, I wish you the best of luck!
jordanvin schrieb:
What I would recommend is to start by changing or painting the fronts.
Hello colmankin, I’m happy to offer you some tips for customizing your IKEA Metod kitchen furniture after installation.
Metod kitchens are designed to allow modular adjustments, but for personalization, it’s best to focus on the following areas:
- Fronts: You can replace them with other IKEA fronts or third-party fronts. The mounting points are compatible, making swaps easier.
- Painting: If you’re comfortable with DIY, you can sand the doors and repaint them with acrylic paint in your desired color. Make sure to use heat-resistant and moisture-resistant paint, suitable for kitchens or furniture.
- Handles: Changing handles is a simple and quick way to transform the look. You can also drill new holes later if you want different handle positions.
- Additional fittings: Interior fittings such as inserts, drawer dividers, or waste sorting systems can greatly improve functionality.
- Open shelves and display cabinets: You can add self-built or IKEA internal shelves.
- Lighting: LED spotlights or strips under wall cabinets or inside glass display cabinets create ambiance.
I always recommend carefully measuring and checking mounting points before making major changes, and using original or compatible IKEA accessories to ensure proper fit.
Feel free to ask if you have any more questions!
colmankin schrieb:
Are there proven methods for making changes by replacing fronts, adding extra elements, painting, or other adjustments that can be done without extensive carpentry skills?For a realistic assessment, allow me to explain:
- Replacing fronts: IKEA itself offers a range of different front designs that are compatible and relatively easy to swap. Third-party fronts are available but must be precisely matched to the dimensions and mounting systems.
- Painting: It is recommended to use water-based, solvent-free paints specifically designed for kitchen furniture. Proper preparation by sanding is necessary for the paint to adhere well. This requires some manual skill.
- Handles and fittings: Replacing handles is straightforward, and additional drilling is possible, but seals need to be taken into account.
- Additional elements: Open shelves and lighting can usually be added with minimal effort but should be securely mounted.
- Customization with films or decals: Heat-resistant, easy-to-clean materials should be chosen here.
Conclusion: Many modifications are possible, but the level of difficulty varies. For beginners, replacing fronts and changing handles are the most practical and safest options.
