ᐅ How can I customize and creatively design IKEA BESTA doors?
Created on: 8 Jun 2017 18:23
Tunejon
Tunejon
8 Jun 2017 18:23
Hello everyone, I want to customize the doors of my current IKEA Besta shelving unit in a creative and personalized way. My question is: What are the options for modifying the Besta doors so that they stand out visually while remaining durable and functional? I am considering different techniques, such as painting, applying adhesive films, or even incorporating special materials. It is also important for me to understand how to handle the doors properly and avoid damage, for example when applying films or paint. Does anyone have experience with DIY projects involving Besta doors and can offer specific advice on the best way to approach such projects? Thanks in advance!
V
vinli
8 Jun 2017 19:47
A good way to customize IKEA BESTA doors is by using high-quality adhesive films. These come in many designs and can be cut to size.
- Important: The surface must be clean and free of grease to ensure proper adhesion and to prevent bubbles.
- An alternative is special MDF boards or wood veneers, which can be cut and glued on to achieve a more refined look.
- For painting, acrylic or specialized furniture paint works best because it is durable and resistant to wear.
- To protect the finish, applying a clear lacquer after painting is recommended to prevent scratches.
Avoid using strong adhesives or spray paints without proper surface preparation, as these can damage the doors.
Tyrese
9 Jun 2017 07:52
Great topic! I painted my BESTA doors with chalk paint, and they look really fantastic! 😊
A little tip from me: just seal them with wax after painting, so everything stays clean for a long time, and you can even wipe it with a damp cloth.
You can also create great patterns using stencils – this turns any piece of furniture into an eye-catcher! So grab your brushes and have fun being creative!
kaudi
9 Jun 2017 14:03
Tunejon schrieb:
My question is: What options are there to customize the BESTA doors so that they not only stand out visually but also remain durable and functional?
Hello, I’m happy to help. There are several creative ways to personalize the doors. Basically, you should pay attention to the following points:
- Material: The laminate on the doors is sensitive, so it’s best to use water-based paints or films.
- Technique: Painting with acrylic paint, covering with vinyl film, or even replacing with glass or metal doors, which IKEA also offers as accessories.
- Protection: Clear lacquer or special furniture wax helps protect the surface.
When applying films, choose ones with air channels to avoid bubbles. When painting, make sure to sand and clean the doors thoroughly beforehand.
If you like, I can provide detailed product recommendations and step-by-step instructions.
V
vinli
10 Jun 2017 10:39
Tyrese schrieb:
I painted my BESTA doors with chalk paint, and it looks really fantastic!
Chalk paint is indeed an option that provides a matte, natural finish. However, it should be noted that these surfaces are quite delicate and wear down quickly without a protective sealant.
Alternatively, I recommend furniture acrylic paint combined with a multi-layer clear coat for a durable surface.
It is also generally advisable to:
- Use fine sandpaper to roughen the surface before painting.
- Work in well-ventilated areas.
- Follow drying times carefully to avoid cracking.
If you are dealing with films: Self-adhesive vinyl films with air channels (like renovation films) make installation significantly easier and longer-lasting.
