Hello everyone, I’m currently thinking about how to modify Ikea Platsa furniture in the most effective way for a home office. Specifically, I want to create an ergonomic and practical workstation solution from the standard cabinets and shelving units. I’m especially interested in tips and examples for integrating work surfaces, cable management, and storage for office supplies — also any advice on stability when making DIY adjustments. Does anyone have experience with the best ways to modify Platsa so that it not only looks good but is also functional for everyday use? Looking forward to your suggestions!
Basically, I find Platsa quite suitable for a home office, as long as you keep a few things in mind. Here is a brief guide:
- Planning: Measure your workspace precisely and consider how much surface area you need for storage.
- Worktop: Use a separate tabletop (e.g., from Ikea or a hardware store) and securely attach it to the Platsa units. Brackets or sturdy screws work well for this.
- Stability: Make sure the modules are firmly connected to prevent wobbling. Often, the original metal connectors are sufficient.
- Cable management: Use cable channels or clips mounted on the back, and if needed, drill small holes in the panels for vertical cable routing.
- Optimize storage: Shelves vary in size, and you can customize drawers with dividers to suit your needs.
Common mistakes include insufficient fastening of the tabletop and lack of stability when the span is too wide. If you like, I can share some close-up photos of my setup.
klo40 schrieb:
Typical mistakes are insufficient fastening of the tabletop and lack of stability when the unsupported spans are too large.I completely agree with that; it frustrated me a lot at first because I only figured it out through trial and error. I was actually a bit wary of the renovation, but once I invested time and tools, the result was really satisfying. The important thing is to have confidence and not give up over small mistakes. That’s very motivating when creating your own workspace.
As a supplement: If you want to modify Platsa modules, you should also consider the maximum load capacity of each individual module. According to the manufacturer, the maximum load is usually around 15 kg per shelf, which means for worktops you should use separate, more robust supports.
I also recommend installing cable grommets with rubber inserts to prevent damage when frequently changing cables. For added comfort, an additional pull-out keyboard tray can be installed if the Platsa units are mounted at desk height.
Pay close attention to the alignment of the modules to each other to avoid uneven surfaces. A set of leveling screws for the feet can easily compensate for any unevenness.
