ᐅ How can I connect IKEA Besta shelving units to maximize space efficiency?
Created on: 2 Feb 2024 10:47
mapa65
mapa65
2 Feb 2024 10:47
I am currently exploring ways to connect multiple IKEA Besta shelving units as space-efficiently as possible, without making the room look cluttered or risking the stability of the units. My goal is to combine different shelving elements, including various heights and widths, to make the best use of the available space—such as wall areas around corners or up to the ceiling. I am especially interested in which connection methods you would recommend to ensure the shelves stand securely while still allowing for easy adjustments or expansions. Are there reliable connectors or accessories from IKEA or third-party suppliers that have proven effective? And how can unattractive gaps or seams be best avoided?
I look forward to your tips and experiences!
DUVIN
2 Feb 2024 11:23
Hi,
I would connect the Besta components using the original IKEA connector plates. This ensures stability. For corner combinations, it’s best to secure them with metal brackets. You can avoid gaps by carefully planning the dimensions. There are also third-party adapters available for gluing or screwing.
nubar
2 Feb 2024 13:12
It is fundamentally important to align the modules precisely before connecting them. The original connecting fittings from IKEA are sturdy but are only suitable for modules with the same height and depth – if the dimensions vary, it becomes more challenging. In such cases, using brackets and additional metal strips can help increase stability at the corners.
I also recommend anchoring the shelves to the wall, especially for taller stacks or multiple units placed on top of each other. For the gaps between the shelves, individual trim pieces or acrylic joint fillers are useful to create a uniform visual appearance.
Additionally, it makes sense to check the planning carefully with a millimeter tape measure before purchase and, if possible, to combine individual modules so that the side edges align flush.
Do you have a specific corner or dimension that makes your planning more complicated?
mapa65
3 Feb 2024 09:08
nubar schrieb:
Is there a specific corner or measurement that makes the planning more complicated for you?
Thanks for the suggestions! Yes, I actually have a somewhat challenging room situation: The wall isn’t perfectly straight, the ceiling is sloped, and I want to create as much storage space as possible under that slope. The shelf widths will vary in places (60cm (24 inches), 120cm (47 inches)), as will the heights (for example, 60cm (24 inches), 128cm (50 inches), 192cm (76 inches)).
So it would be great to have a flexible yet stable connection that can compensate for small irregularities while still looking flush.
DUVIN schrieb:
There are also third-party adapters for gluing or screwing.
Could you describe these in more detail? Are there any particular brands or product types you would recommend?
I’d also like to know how you handle the appearance of the transitions, especially when combining different heights.
Jensson
4 Feb 2024 15:37
Hello mapa65,
I would like to give you a brief guide on how I assembled my Besta combinations, so you can get an overview:
1. Planning:
- Create an accurate sketch including heights, widths, and wall conditions.
- Measure every wall and slope carefully, allowing small tolerances for unevenness.
2. Connection:
- IKEA offers so-called "connector plates for Besta," which you can use to connect shelves horizontally and vertically.
- For irregular areas, use flexible metal brackets that you adjust to compensate for slight unevenness.
- Third-party manufacturers offer so-called "clamps" or "clips" that can be used for secure wedging and fixing.
3. Stability:
- Always connect the shelves at multiple points and additionally secure them properly to the wall.
- For tall combinations, use IKEA’s safety bars as locking devices.
4. Appearance:
- Use edge protectors or acrylic sealants for the joints.
- For different heights, finishing strips or front panels help to create visually harmonious transitions.
If you like, you can send me the measurements, and I will give you my assessment on the best way to combine them. This helps avoid unattractive gaps and ensures stability.
I hope this helps you for now!
