ᐅ How can I secure Malm bed legs more firmly?
Created on: 22 Mar 2022 19:07
sartill
Hello everyone, some time ago I bought the IKEA Malm bed and overall I’m quite satisfied. However, I’m having some concerns about attaching the bed legs. The screws don’t seem to hold firmly, which is especially noticeable when moving the bed – the legs wobble slightly and it lacks a feeling of sturdiness. My specific question is: how can I secure the Malm bed legs more firmly so they hold safely and permanently? Are there any special techniques or tools that can be used to better fix the screws without damaging the bed frame or the material? I appreciate your expertise and tips, and if anyone has experience with this model, please share! Many thanks in advance.
sartill
23 Mar 2022 08:46
Guyju schrieb:
Finally, I apply threadlocker to the threads to prevent them from loosening.
That sounds interesting. Could you briefly explain what exactly that means? Are there specific products you would recommend? Especially in the bedroom, I want to avoid any unstable spots to ensure the legs remain secure even after extended use.
Guyju
23 Mar 2022 09:34
Gladly! By "threadlocker" or "Loctite" (a well-known brand name), we mean a secondary adhesive applied to the threads of screws. There are different strength grades:
- Low strength: For screws that you want to be able to remove later but still need vibration resistance.
- Medium strength: For permanent fastenings that must withstand all stresses.
When applied to the threads, it prevents screws from loosening due to movement. Important: Do not use too much and tighten the screws firmly after applying.
These products are often available at hardware stores and are specially designed for furniture or machinery. Alternatively, you can also use threadlocking paint, which has a similar effect.
Joshbe
23 Mar 2022 13:15
In summary, the stability issue with IKEA Malm bed legs is mainly caused by material properties – thin wood and flexible joints. Technically, there are three main approaches:
1. Reinforcing the screw holes with wooden dowels or wood shavings plus glue
2. Using high-quality screws with a slightly larger diameter and appropriate length
3. Applying thread locker for a durable hold without causing damage
The use of metal brackets is an additional mechanical improvement that makes the overall structure more stable. It is important to carry out all measures carefully to avoid damaging the furniture.
If you have multiple pieces with similar problems, you might also consider replacing the bed legs with models that have separate mounting plates, as these are usually more stable.
ronti
23 Mar 2022 15:42
Insert wooden dowels into the screw hole, apply glue, and let it dry. Then insert the screw; the reinforcement is clearly noticeable. Apply screw threadlocker to the screw for longer-lasting hold.
KIN42
24 Mar 2022 07:19
sartill schrieb:
Could I perhaps use so-called Spax screws instead of the original screws?
That's a good consideration. Spax screws are better suited for wood due to their special thread compared to standard screws. However, pay close attention to the length and diameter (around 4–5 mm (0.16–0.20 inches)) to ensure they neither damage the material nor are too short. It’s best to measure in advance so they grip well in the wood without splitting it. If you’re unsure, you can test a screw on an inconspicuous part first.
