ᐅ How can I customize Ikea PLATSA units for installation on sloped ceilings?
Created on: 25 Feb 2021 20:43
Saidnau
Saidnau
25 Feb 2021 20:43
I am planning to install an Ikea Platsa system in my apartment, but the challenge is that the available space is very limited and sloped due to the roof angle. My question is how to best adapt the Ikea PLATSA to fit sloping ceilings so that it looks good and remains stable.
I have considered cutting individual modules or modifying the back panel to account for the slope, but I have no experience with this. How have you solved this if you have installed PLATSA in rooms with difficult shapes, such as under sloped ceilings? Are there any special tips, materials, or tools I should use for this?
It would be great if someone could share practical advice or experiences, perhaps also regarding installation options for sloped tops or securing the unit to the wall under the slope. Thanks in advance!
tolokau
26 Feb 2021 07:12
Hello Saidnau,
regarding your topic about Ikea PLATSA and adapting it to sloped ceilings, I’d like to share some structured tips based on how I implemented it myself:
- Preparation: Measure your sloped ceiling very precisely, taking multiple points along the slope, as it often isn’t entirely even.
- Adjusting modules: PLATSA is modular and comes in different depths. Use shorter or shallower modules, or trim them as needed—especially the back panels, which can be easily cut to size.
- Implementing angled tops: I adjusted each module with a miter saw so the top edge exactly follows the slope of the ceiling. This can be a bit tricky but results in a very clean finish.
- Fastening: Stable wall mounting is very important. Sloped ceilings often have challenging fixing points. I used additional sturdy brackets to secure the modules against slipping.
- Wall finish: If it fits the aesthetic, I recommend painting or covering the back panel when it’s made of particleboard to reduce moisture and dirt buildup.
- Tools: Besides a miter saw, a tape measure, spirit level, and clamp are useful for safely holding the modules in place while cutting and screwing.
- Tip: Don’t leave big surprises for assembly time. Allow enough time because sloped ceilings require special precision.
If you want, I can go into more detail on specific steps or share my sketches.
Good luck with your project!
BARSAN
26 Feb 2021 15:39
tolokau schrieb:
PLATSA is modular and also offers different depths.
Exactly, first assemble a few modules as a test fit and check how they fit under the slope. Then you can cut more easily.
tolokau schrieb:
I adjusted the modules with a miter saw so that the top edge exactly follows the roof slope.
A precise miter cut is really the best way to ensure everything fits cleanly.
tolokau schrieb:
A very important aspect is secure wall mounting.
What I would add: Use metal brackets whenever possible, attaching them in inconspicuous places. This way, you prevent the stability from decreasing over time.
JEREMIAH38
27 Feb 2021 09:08
I can only agree with BARSAN and tolokau – at first, I was a bit intimidated by my sloped ceiling because everything needs to be cut so precisely.
Maybe it helps not to put too much pressure on yourself to get everything perfect right away. With my PLATSA, I started by loosely assembling the individual parts and then adjusted them step by step to fit the slope. I also accepted small gaps, which I later covered with trim.
tolokau schrieb:
PLATSA is modular and offers different depths.
I found that very helpful because I could experiment with various depths and even left one corner partially open.
BARSAN schrieb:
Use metal brackets wherever you can attach them in less visible areas.
With the metal brackets, you definitely get a secure fixing.
If you want, allow yourself some extra time for cutting, because sometimes there are slight variations in the wall alignment or slope that you only notice during assembly.
Stay patient, and if you’re not very experienced with sawing, try a test cut before working on the entire unit. I know it sounds obvious, but sometimes a reminder helps a lot.
