I have a problem that probably many owners of Billy shelves know: my pets (especially my cat) keep leaving small scratch marks and sometimes small bite marks on the edges and surfaces of the shelves. Over time, this damages the finish and looks unattractive.
How can Billy shelves be effectively protected against such pet damage? I’m not only thinking about temporary deterrent measures but also about ways to preserve the stability and appearance of the shelves in the long term without completely rebuilding or making them inconvenient to use.
Do you have any tips regarding materials, protective films, maintenance, or other tricks? I would appreciate detailed answers, preferably with personal experiences. Thanks in advance!
Hello Emelpi,
I’m familiar with your problem, as I had similar issues with my Billy bookshelf and my cat. Generally, I would recommend first applying special protective films made of polycarbonate or scratch-resistant film to the areas of the shelf that are most frequently scratched. These are transparent and do not affect the appearance.
If your cat often climbs on the shelf, you can also use plastic or rubber edge protectors, which are easy to install and help prevent mechanical damage.
Additionally, diffuse barriers such as deterrent sprays (safe and suitable for cats) can help if you want to keep your cat away from certain parts of the shelf.
And don’t forget: provide variety so the shelf doesn’t become interesting to scratch in the first place. Toys, scratching posts, or catnip can help redirect the scratching behavior.
If you like, I can also send you links to some products.
Hello Emelpi,
I would like to provide a more technical and detailed response because protecting Billy shelves from pet damage actually requires some careful planning.
First, you should consider what type of damage is most common: with cats, it is usually scratching, while dogs sometimes cause biting damage or moisture from saliva. The material of the Billy shelf is typically particleboard with a laminate coating, which is not very resistant to mechanical damage.
A multi-layered protection approach would therefore be advisable:
1. Protective films: As Kugau already mentioned, very thin polycarbonate or PET films are suitable; they are transparent and can be easily applied to the surface. Make sure the film has a high scratch resistance (at least 3H hardness on the pencil hardness scale).
2. Edge and corner protection: The shelf edges are the most vulnerable spots. You can install special furniture protectors made of plastic or metal here. They are easy to apply and can be replaced if needed.
3. Surface protection with coating: An additional coating with a scratch-resistant clear varnish (e.g. PU varnish) on the shelf surfaces can provide extra protection, although applying it on laminate coatings can be somewhat complex, as adhesion may vary.
4. Barrier methods: For areas that do not necessarily need to be accessible, I recommend arranging the shelf with plants or other furniture to discourage your pet from approaching.
5. Training and distraction: At the same time, you should try to get your pet accustomed to using new scratching posts (e.g. sisal scratching posts) and toys.
Could you please describe in more detail how your pet is damaging the shelf? Only then can I offer more targeted advice for your situation.
Thanks in advance for the detailed answers!
Regarding your question, Lance: Most of the scratches are caused by the cat on the vertical edges of the shelves. The cat uses these edges as a scratching spot, probably because of their height and texture. I haven’t observed any biting so far, so that’s not a major issue.
I’m also willing to apply protective films or make small modifications, but I want to minimize any impact on the original appearance of the shelves.
What do you think about self-adhesive protective strips or furniture edge guards? Are they durable enough for long-term use? And how easy is it to remove them if I want to sell the shelves or redecorate?
I’m open to further suggestions!
Emelpi schrieb:
What do you think about self-adhesive protective strips or edge profiles for furniture?They are a convenient and effective solution, especially if they are designed for furniture and removable. Pay attention to the product specifications. In some cases, I recommend edge profiles made of hard plastic, as they tend to be more durable.
But in general: good adhesion means good protection, while poor adhesive leads to annoying peeling.
