ᐅ Floor Plan Design for a 150 sqm Single-Family Home – Tips for Improvement?
Created on: 22 Jan 2019 13:30
Franky73
we are in the process of building a single-family house with a basement suitable for living. This is the design we have come up with. I would like to hear from you if you see any possibilities for improvements.
On the ground floor, there is a side entrance door on the right. The carport will be located there.
In the basement living area, the children's rooms face south. From there, it should be possible to access the terrace and the garden.
I look forward to your tips and suggestions!
Ground floor plan: open living and dining area, kitchen, bathroom, hallway, and two rooms.
Apartment floor plan: kitchen, living room, hallway, and bedrooms with dimensions.
Franky73
25 Jan 2019 16:26
Zaba12 schrieb:
I just wanted to mention it. You don’t want your house to end up more expensive than mine.
The development plan specifies a single story. The architect can’t just change that. So why do you leave the meeting and she draws you three floors?
I just want to understand!
As stated:
  • Basement: Allowed to protrude 1.40 m (4.6 feet) above ground level—so it’s implemented this way and doesn’t count as a full floor.
  • Ground floor: Full floor.
  • Attic floor: Designed so it doesn’t qualify as a full floor.
kaho67425 Jan 2019 16:28
It's manageable. UG = basement, EG + DG. In total, it's only one floor above ground.
haydee
25 Jan 2019 17:34
It’s probably best to spread everything over 3 floors.
The ground floor has the fewest restrictions and the largest living area with the smallest space program.
11ant27 Jan 2019 02:50
Franky73 schrieb:
I will post the basic information here again shortly, that goes without saying!
Apparently not: You have been here long enough to know that this information belongs in post #1, not in post #40 :-(
Franky73 schrieb:
We had 8 other quotes available for comparison.
Don’t forget that large differences between quote amounts are more likely a sign of inexperienced tendering rather than proof of effective competition.
Franky73
27 Jan 2019 10:53
Don’t forget that large differences in bid amounts usually indicate inexperienced tendering rather than being “proof of effective competition.”
The current bid is definitely not the "cheapest"!
At the time, I took the effort to list and compare all the items from each supplier in an Excel sheet. For example, if a bid was missing the multi-utility house entry or the retaining walls, I included the expected costs for those items in my calculations to make a "fair" comparison possible.
haydee
27 Jan 2019 11:33
That's good if you take the trouble to do it.
