ᐅ Floor Plan for a 150 m² Corner Bungalow with Expansion Options
Created on: 5 Feb 2022 01:31
Ramona13
Hello 🙂
After what felt like hundreds of crumpled drafts in the recycle bin, we finally have a floor plan that we like and that fits our size requirements. Initially, we planned way too large, sometimes over 250m² (2700 sq ft) of living space... oops... Now we have settled on a nice 150m² (1600 sq ft) 🙂
We mainly reduced the number of rooms. Originally, we planned 2 offices and 2 future children’s rooms, but now only 2 offices remain, with at least one definitely convertible into a children’s room. This makes more sense since we don’t want to seriously consider having children before at least 5 years from now. We also initially planned a small wellness area with a sauna, loungers, and a hot tub inside the house, but this will now be a separate building in the garden.
More generally, I have already written here https://www.hausbau-forum.de/threads/vereinigung-zweier-Grundstücke-baufenster-neu-legen.42280/ about our plots. The request for merging them is still in progress, so we don’t have a definitive location for the house yet. Ideally, we’d like it centered on the current boundary line or, alternatively, on the rear building plot with border development facing the neighboring property.
Fortunately, regarding the development plan/planning restrictions, we will have quite a bit of flexibility. We can submit a preliminary building inquiry to check if everything is acceptable. The last house built here in the village about 4 years ago had 2 full floors, a different roof pitch, and presumably got some exceptions approved without problems. The community is generally happy that we want to fill a building gap 😉
Plot size: approx. 1500m² (0.37 acres)
Slope: no
Floor area ratio & plot ratio... very confusing 🤨
Building window, building line and boundary
Edge development
Number of parking spaces
Number of floors: 1
Roof shape: gable roof, half-hip roof
Style
Ridge orientation parallel to street
Maximum heights/limits
Additional requirements: knee wall 0-50cm (0-20 inches)
Homeowner Requirements
Corner bungalow with gable roof, modern with Japanese elements
Timber construction by local carpentry with the possibility of contributing a lot of own work.
Basement, floors
No basement, 1 floor
Number of people, age
25 (female) and 28 (male) + 2 cats
Children not planned initially, earliest in 5 years
Space needs ground floor / upper floor
Separate offices for home office
Guest bedrooms per year
Very few
Open or closed layout
Open living area
Conservative or modern design
Modern
Open kitchen, kitchen island
Kitchen island facing the garden, pantry as a separate room behind the kitchen
Number of dining seats
4-6
Fireplace
No
Music / stereo wall
No
Balcony, roof terrace
No
Garage, carport
Probably carport, but not decided yet
Utility garden, greenhouse
Vegetable garden with large greenhouse definitely planned on the property
Other wishes / special features / daily routine, including reasons why some things are or are not desired
- A gallery in the roof, open to the living area, would be a big dream of mine, but only if financially feasible. Otherwise, this part of the roof will be storage space or intended for later expansion.
- Smart home with KNX installed by ourselves (all electrical work will be DIY in cooperation with a certified electrician who will inspect and approve)
- Controlled mechanical ventilation and a separate split air conditioning system
- Photovoltaic system on the roof facing south and east
- Garden must be cat-proof fenced since our cats are not outdoor cats (currently strictly indoor cats)
- Exposed beam ceiling in the open living area
Designer:
- Do-it-Yourself
The open living area with the possibility to use both the south and north terraces.
Small “reading nook” at the end of the hallway with a large seat window (-> if there is a gallery, the staircase will lead upstairs here and the reading nook will be located there)
What don’t you like? Why?
Maybe the hallway is too long...
Estimated cost according to architect/planner: none yet, appointment with architect next week.
Personal price limit for the house including equipment: we hope to stay under €500,000 (approx. $540,000)
Preferred heating technology: air-water heat pump with underfloor heating
If you had to give up, which details / expansions
- could you do without:
- Gallery would be nice but is not essential
- Wellness area in the garden can be built later
- Reading nook
- could you not do without:
- Air conditioning
- KNX system
- Separate offices
- Cat-proof garden
Why did the design turn out this way? e.g.
Standard draft from planner?
Our design developed step by step from many sketches, floor plans, and photos found online.
The interior furnishing in the 3D images is only a placeholder; the detailed interior design is still being planned.
Finally, this design gives us a satisfied feeling in terms of size and room layout 🙂
In your opinion, is our project achievable for a maximum of €500,000 (approx. $540,000), and is it sensible to plan smaller first and then expand by adding a loft conversion?
I am very grateful for your opinions, ideas, and suggestions for improvement! 🙂
driver55
22 May 2022 11:53
In February, there were already reports of hundreds of crumpled floor plans, and three months later, the final design is still not finished...
(that means the floor plan has been worked on for months without resolution…)
If a professional had been hired right away (who would have to be involved anyway), this issue would probably have been solved long ago, saving several thousand dollars, especially considering the current interest rates.
11ant22 May 2022 12:38
driver55 schrieb:
If a professional had been hired right from the start (who would have to be involved here anyway), this issue would probably have been resolved long ago.
The expert was already found, but on a key point (mechanical ventilation with heat recovery) she has a different approach than the homeowners. So she was sent away again (rightly so), and now they want to try to manage it only with the contractor instead of a designer (nonsense).
29 May 2022 17:23
For bad weather days, I designed this bungalow as a project and spent a few days adjusting the walls.
Of course, I stumbled over the 500,000€ again. It seems that the ancillary building costs are also supposed to be covered by this amount.
So, I set a limit of about 450,000€ for a bungalow with expansion potential, around 140/150 sqm (1500/1600 sq ft) on the ground floor. Regarding the mentioned electrical installations, I assume the expansion of the attic is included in the budget.
I tried orienting the L-shape of the house with a southwest-facing terrace, but for me, that led to a dead end.
Also, I limited myself to the rear part of the plot so that the front could possibly be sold later, keeping south sun exposure and a north view. Well, that didn’t work out.
The husband prefers everything facing north for the nice view. No children planned yet, and a large bungalow in the middle would be too dark again.
In short: this is what comes out now, but I would personally still refine it. For the presentation, this rough sketch should be enough.
-> Note on the attic: With 50cm (20 inch) calcium silicate blocks (was that required?) and a 30-degree roof pitch, this is what you get. Knee walls of about one meter (3 ft) reach a height of roughly 100cm (39 inch), and the roof’s midpoint is at 200cm (79 inch) room height. That’s not great! Although the house is nearly 10 meters (33 ft) wide here.
Regarding the location: I would place the house as far east as possible, so that there is plenty of space to the west (the neighbor was mentioned)... Maybe also the carport to the south, leaving only about 3 meters (10 ft) on the east side.
The staircase dimensions here are somewhat below standard, since it would be used more with plan B. Ultimately, a lot would have to be adjusted anyway, or with a 33-degree roof pitch, the attic might be accessible via the stairwell. I think you can see where the problems lie.
Floor plan of a residential house: open living area, office, bedroom, bathroom, WC, stairwell, utility room, technical room, two terraces.
Of course, the software fails with the roof 😉
Floor plan of a residential layout with corridor, bathroom, child’s room, child/office and void
Floor plan of a house: open living/lounge area, bedroom, office, bathroom, WC, utility room, technical room, terraces.
