Who here can share their experience with solid wood oil-finished countertops in the kitchen? I have chosen Iroko wood but have not ordered it yet because I have some concerns about moisture. Greetings from Upper Austria
nordanney18 Aug 2021 23:50i_b_n_a_n schrieb:
Can you share some information about the prices of Iroko? I'm still undecided about my new countertop ...Starting at around 100€ per meter (about 100 US dollars per meter). For example, I would buy it from worktop-express.Myrna_Loy schrieb:
Over the past few years, I’ve tested all kinds of countertops, and wood is, alongside ceramic, my favorite. However, only oiled countertops tend to stain quickly. For solid wood, I like using hard wax oil – it’s also food-safe, and it makes the countertops nearly indestructible, even around the edges.Does hard wax oil also help around the stove area when grease often splatters?
We’ve had an oak countertop for 10 years, and I would definitely choose real wood again at any time. The patina and even occasional marks from a hot pot or unnoticed spilled vinegar don’t bother me at all. If necessary, you could sand it down.
But around the stove, the wood tends to turn gray and dry out quickly from dish soap. In theory, I could re-oil it every few weeks.
For the rest of the countertop, applying oil every few months is sufficient.
It is interesting that almost everyone here focuses solely on aesthetics.
My concerns are more related to wood warping and cracking. This is hardly predictable because it largely depends on how the current board was cut from the log and how close it was to a knot.
I have two cases where solid wood components warped so much over the years that their original function was practically lost.
In the future, I would only use plywood or a box structure (if thicker), possibly with a solid wood edge strip on the front to maintain the appearance.
Myrna_Loy19 Aug 2021 11:05You should never cut from a single board. Always use laminated wood for countertops. With good quality, the glue joints will not come apart unless exposed to large amounts of water for an extended period.
We have had an oak countertop measuring approximately 3.7 x 1.2 meters (12 x 4 feet) on our kitchen island for about three years. The carpenter made it in several layers to prevent warping. I refresh the surface once a year with an emulsion. Around the sink and cooktop, the surface still looks like new. Only in between, where all the food prep happens, there are some signs of wear. I actually like it that way, and if it gets too worn, I simply sand off the top layer.
hampshire19 Aug 2021 23:27In 1995, I had ash countertops installed in our small apartment in Berlin. They have been moved three times and are still “much loved,” now installed in our entrance laundry room. Of course, there are some scratches. So far, moisture has not been an issue.
