ᐅ Easily Retrofit and Adjust Soft-Close Doors for Ikea Metod Cabinets
Created on: 11 Jul 2019 08:37
SAN59
Hello everyone, I recently installed my kitchen using the Ikea Metod system and would like to retrofit the already mounted doors with a soft-close function. My goal is to add this feature as easily and quickly as possible and then adjust it optimally so that the doors close smoothly and quietly. I am particularly interested in which exact parts are needed, whether any special tools are required, and how to best adjust soft-close doors on the Metod system. Perhaps someone here has experience with this and can explain the process step by step—ideally with tips on what to pay special attention to, so the retrofit really works without any issues. Thanks in advance!
Thanks for your initial feedback, it’s really helpful! I still have one question: The Metod hinges often come with so-called clip-on mounting plates – is the installation of the soft-close hinges exactly the same? In other words, can I simply “clip” the new hinges on, or do I need to get more complex mounting components?
Also, I’ve heard that you need to be especially careful when adjusting doors with soft-close systems because otherwise they might not close properly or the door panel could hang unevenly. Is there a specific recommendation for Metod hinges on how to best proceed without having to frequently readjust?
SAN59 schrieb:
With Metod hinges, there are often the so-called clip-on mounting plates – is the installation of the soft-close hinges exactly the same, meaning can I simply “clip in” the new hinges?Yes, exactly. Ikea uses a universal system – the soft-close hinges use the same mounting plates, so they are clip-on. You can easily replace the hinges without buying new plates.
SAN59 schrieb:
Is there any specific recommendation for Metod on the best way to proceed without having to constantly readjust?My advice: Hang the door roughly, tighten all screws lightly, then make the final adjustments. The system is designed so you can adjust in three directions (up/down, in/out, sideways). Proceed step by step and don’t overdo it at once. This way you avoid unnecessary fiddling.
Good morning!
Exactly! And if you’re wondering why the clip system is so brilliant: it saves you what feels like hundreds of screws and still holds perfectly tight. For anyone hesitant about retrofitting at first – just be confident, position it, apply gentle pressure and *click*, done!
A little fun fact – when I installed my first soft-close doors, I initially thought I mounted the mounting plate incorrectly because it went on so smoothly. But it really fits perfectly. So don’t be shy, it just works like clockwork.
neoren schrieb:
You can easily replace the hinges without having to buy new plates.
Summary of Soft-Close Retrofit for Metod:
- The soft-close hinges are compatible with the existing clip mounting plates, so no additional drilling or modification of the plates is necessary.
- Make sure to always use the complete soft-close mounting kit, not just retrofit damping elements, as these can often be unreliable.
- Three adjustment screws control the fine-tuning, which are easy to operate with a Phillips screwdriver: height adjustment, lateral adjustment, and depth adjustment.
- It is recommended to mount the doors roughly first and then perform the fine adjustment to avoid misalignment.
- Smooth closing results from the hydraulic mechanism in the hinge, which works perfectly when installed and adjusted correctly.
If you notice significant issues with closing, first check the alignment of the door to the cabinet body and adjust the hinges as needed.
Fitigu schrieb:
Soft closing is the result of the hydraulic mechanism in the hinge, which works perfectly when correctly installed and adjusted.That’s exactly the point! Especially if you’re unsure about retrofitting, this understanding is very helpful: the soft-close feature isn’t just a gimmick, but a precise technology that doesn’t function optimally if installed incorrectly.
Another tip from my own experience: always make adjustments in small increments. What worked for me was roughly aligning the door only on one side at the hinge mounting first, then fine-tuning on the other side. Always close the door several times between adjustments so you can feel how the closing mechanism behaves.
Have you had similar experiences or perhaps specific tips for lint- and slam-free closing?
