ᐅ Drying out a newly constructed house (whole building)? (Dehumidifiers)
Created on: 5 Oct 2014 22:06
U
uwe72
U
uwe72
5 Oct 2014 22:06
The liquid screed has now been in the house for about 6 weeks.
Since shortly after that, the underfloor heating has been running constantly.
For about a week now, two dehumidifiers have also been running in the basement: a large one in the utility room and a smaller one alternating between the office and the guest room.
I am not sure whether the basement windows should be open, closed, or tilted.
When the basement windows are closed, we have about 35% humidity at around 28°C (82°F).
Yesterday, I aired out the basement briefly by opening the windows wide, and afterwards the humidity rose to about 60%.
How can I achieve the best result?
Thanks and best regards!
Sharky
25 Oct 2014 22:45
Windows open ... Warm air can hold more moisture than cold air ... (a dehumidifier is also more effective with warm air) ... The ideal relative humidity is between 40% and 60%
Fassadendoc30 Oct 2014 19:14
When using dehumidifiers, windows must remain closed at all times. The rise in relative humidity occurs due to the temperature drop after airing (ventilating).
Bauexperte
30 Oct 2014 20:21
Good evening,
Fassadendoc schrieb:
When using dehumidifiers, the windows must remain closed. The rise in relative humidity occurs due to the temperature drop after ventilation.
It wouldn’t be so bad if you would at least disclose your qualification for the above statement in your profile….
Regards, Bauexperte
Saruss
31 Oct 2014 08:53
So, the statement is understandable to everyone through basic physics and can be verified within about 2 minutes if necessary.
Bauexperte
31 Oct 2014 10:38
Saruss schrieb:
Well, the statement is clear to anyone based on simple physics, possibly verifiable within 2 minutes.
That might be true for you and a few other users. However, I strongly doubt that every reader or contributor here can verify it as well. And if the user trusts the statement blindly (since the internet is always right), I want to be assured that there is a professional behind "Fassadendoc," or at least an experienced builder.
Regards, Bauexperte
