ᐅ New Build 2014: Issues with High Humidity in the Basement
Created on: 8 Jul 2015 13:06
Maestro1983
I would like to describe my problem to the experts in this forum and hope someone can finally provide a helpful solution.
I have spent weeks reading extensively online and still don’t know what to do.
From 2013 until the end of 2014, I built my own home with a lot of personal effort. Except for the basement, everything else is perfect!
The house has a full basement. The basement is almost filled up to lawn/patio level. On two sides of the house, the basement still sticks out about 10-20 cm (4-8 inches). The rest will be filled by August at the latest.
Key details:
The basement has a gross floor area of about 100 m2 (1,076 sq ft), divided into several rooms. Three rooms have 1 x 1 m (3 x 3 ft) windows.
A straight staircase leads up to the ground floor through a small hallway (about 6 m2 (65 sq ft)). The basement staircase does not have a separate door because it only opens into this small room. This room has a door to the garage and a door to the ground floor corridor. The temperature in this small hallway is usually between 20-24°C (68-75°F).
Basement floor construction:
Tiles
Screed about 5 cm (2 inches)
PE foil
Bitumen membranes (the floor slab is completely sealed)
24 cm (9.5 inches) concrete slab
10 cm (4 inches) gravel layer
The basement’s exterior walls are built with 36.5 cm (14 inches) Poroton blocks. On the outside, they are first plastered, then coated with a thick bitumen waterproofing membrane, and in front of that, there is 5 cm (2 inches) of perimeter insulation.
No insulation was installed under the floor slab, and the outer walls were insulated only with the 5 cm perimeter insulation because it was intended to be an unheated utility basement.
Now, the major problem:
All exterior walls are now developing mold spots during the summer (I already had issues in spring as well). The rooms have a musty smell.
Most mold occurs at the base of the walls near the floor, probably where it is coldest, but some spots appear higher up on the walls as well. I have tried treating them repeatedly with methylated spirit or similar products.
I have also read many forums about ventilation and similar issues. The humidity level remains between 75-80%. Using a dehumidifier only lowers it temporarily. After a few hours, the high level returns.
I know that ventilating regularly does not help long-term, and running a dehumidifier constantly in every room is not feasible. I have been testing different ventilation methods for weeks.
It only creates effort and does not help at all!
I can definitely rule out moisture coming in from outside through the walls or floor slab. Residual construction moisture is also excluded because I have used professional dehumidifiers and removed buckets of water.
Somehow, moisture always finds its way into the basement and causes everything to rot.
Using additional heaters installed afterward also does not help. The rooms warm up slightly, but the humidity remains the same. Currently, the basement temperature is about 16-18°C (61-64°F).
How can I achieve a low humidity level? Should the exterior walls be insulated from the inside afterward to raise the temperature and prevent condensation? Would this automatically lower humidity if insulation is applied to the walls?
Would it help to install insulation panels around the base of the exterior walls at floor level, about 50 cm (20 inches) high? How thick should the panels be?
I cannot afford to excavate and insulate the outside walls completely again, especially to add thicker insulation—it would be very expensive! Also, the floor slab bottom would still not be insulated.
Unfortunately, I didn’t realize before construction how many problems a cold (only minimally insulated) basement could cause! I cannot store anything in the basement.
I hope someone can help me!
THANK YOU VERY MUCH!
Lumpi_LE
13 Jul 2015 08:17
There is definitely a construction defect (waterproofing) at the wall junctions, especially with water pressure involved... it already starts with the fact that you fully welded a waterproof concrete slab?
A building expert will be able to help.
Regarding ventilation, as just mentioned: If you ventilate your 16°C (61°F) basement in summer, it will inevitably become more humid...
Maestro1983
14 Jul 2015 06:45
Lumpi_LE schrieb:
There is definitely a construction defect (waterproofing) at the wall junctions, combined with hydrostatic pressure... it already starts with you completely welding the waterproof concrete slab?
Regarding ventilation, as just mentioned: if you ventilate your 16°C (61°F) basement in summer, it will inevitably become more humid...
Hello lumpi_LE,
We fully welded the floor slab with bituminous membrane. Then the masonry was built on top. In the first course of bricks, we also installed a membrane layer. On the outside, we applied thick-bitumen coating up to the underside of the floor slab. Because of this, I would personally exclude hydrostatic pressure as the cause. Even after two weeks of dry weather, the humidity inside simply does not drop. After turning off the dehumidifier, the humidity rises back to about 75% within an hour.
A building expert has already been commissioned. He is trying to come this week.
I hope he will bring some clarity!
Maestro1983
14 Jul 2015 07:03
wrobel schrieb:
I would like to clarify some basic things quickly.
How and when do you ventilate?
Olli
Hello wrobel,
I ventilate less often during the summer. Mostly late in the evening or early in the morning. Then I open all the basement windows fully for about 15 minutes. I make sure that the outside temperature is about 5 degrees Celsius (9°F) lower than the basement temperature and that the outdoor humidity is significantly lower as well.
I have also understood that you should probably compare the outside temperature with the wall temperature. But if that is only around 10 to 15 degrees Celsius (50 to 59°F), you can hardly ventilate at all in summer…
For the last six days, I haven’t ventilated and have been running the dehumidifier. I recorded a maximum humidity of 78% in the basement hallway.
bernie
6 Nov 2018 18:24
Since the original poster did not respond further: How did the situation develop? What did the expert say???
