ᐅ Is it necessary to retrofitting floor supports in Kallax units for heavy-duty use?
Created on: 18 Jul 2023 08:37
V
vinleHello everyone, I’m currently considering whether it is really necessary to retrofit additional shelf supports for heavy-duty use in the IKEA Kallax shelving unit. As you know, the Kallax isn’t equipped with extremely load-bearing shelf supports; the standard shelves seem sufficient for most purposes, but once you want to store heavy items—such as thick stacks of books, boxes with tools, or electronics—the question arises whether the included shelf supports can really handle the load or if upgrading them makes sense.
I would like to know if anyone here has practical experience with retrofitted shelf supports or if they are essential when using the shelving unit not just for decoration but also for truly functional and heavy-duty use. How is the stability, and which options are best suited to reinforce the shelving without resorting entirely to custom-built solutions? Looking forward to your assessments and tips!
vinle schrieb:
whether it is really necessary to retrofit shelf supports for heavy loads in the IKEA Kallax shelving unitHey, great question! 😊 I think if you want to store really heavy items, the original shelf supports might reach their limits. The shelving unit is designed more as a lightweight everyday helper.
I simply installed additional metal shelf supports myself – they’re inexpensive, easy to fix, and provide significantly more stability to the unit. It’s a quick upgrade, and the difference under load is noticeable.
If you only plan to store books and medium-weight items, it usually works fine without them. But for very heavy loads (toolboxes, for example), I wouldn’t skip them. 🙂
vinle schrieb:
whether it is really necessary to retrofit shelf supports for heavy use in the IKEA Kallax unitBasically: The Kallax system uses shelves that are supported by a combination of plastic shelf supports and the side panels of the unit. The standard plastic supports are designed more as guides than as primary load bearers.
For heavier loads—I’m talking about more than around 15-20 kg (33-44 lbs) per shelf—it is definitely advisable to retrofit in order to prevent sagging or even the plastic clips snapping out. Metal shelf supports or additional battens for reinforcement are recommended.
Depending on how the unit is used, it is also a good idea to secure the back panel, as this increases the unit’s torsional stiffness. When retrofitting, make sure that the fixings do not cause any deformation to the unit. Sometimes it helps to carefully measure the exact positions of the supports and space them evenly.
I’m curious: What heavy items are you planning to place on the unit? That way I can provide better advice on load distribution.
kulau schrieb:
Depending on how the shelf is used, it is also recommended to secure the back panelSecuring the back panel is a very good point. Even simple metal shelf brackets are affordable and easy to retrofit. Definitely advisable for heavy loads.
kulau schrieb:
Depending on how the shelf is used, it is also recommended to secure the back panel, as it makes the unit more torsion-resistant.I completely agree. However, you shouldn’t focus only on the shelf supports.
For me, the fundamental question is whether a Kallax is the right piece of furniture for very heavy loads. It is a modular furniture unit but not designed for industrial or permanently heavy use.
If really heavy items need to be stored, I would consider whether a sturdy steel shelving unit might be better, since reinforcing a Kallax only provides limited additional stability. The shelf supports do improve the load capacity of the shelves, but the entire frame can bend or warp under overload.
Are there any specific maximum weight ratings from IKEA for the Kallax shelves? In my experience, the recommended load per shelf is around 13–18 kg (29–40 lbs). Anything beyond that should be approached with caution.
