ᐅ Using Kallax Shelving as Storage for Household Appliances – Is It Durable Over Time?
Created on: 20 Oct 2023 18:43
kepa63Hello everyone,
I am considering whether the Kallax shelf unit from IKEA is really suitable as a permanent support surface for heavy household appliances. Specifically, I’m interested in whether the construction of the shelf panel and the overall load capacity of the system can withstand appliances like washing machines, dryers, or larger kitchen devices over the long term without sagging or becoming unstable.
What are your experiences with this? Have there been any durability issues when repeatedly placing heavy appliances on the Kallax over several months or years? Or are other shelving systems better suited for this purpose?
I would greatly appreciate expert opinions and experiences, including technical details about the load-bearing capacity of the Kallax shelves.
Thanks in advance!
Thanks in advance!
According to the manufacturer, the maximum load capacity of a single Kallax compartment is usually about 13-15 kg (29-33 lbs), which is clearly too low for household appliances like washing machines or large kitchen appliances. The panels are made of particleboard with a melamine coating, which can warp under continuous load.
In addition, the joints of the side panels and back panel are not designed to securely support the weight of heavy electrical appliances. Over time, there is a risk of material fatigue and sagging.
For consistently heavy loads, a sturdy metal or solid wood shelf with certified load capacity is therefore recommended.
Hello kepa63,
In questions like this, it is important to differentiate carefully. Kallax was originally designed as a shelving unit for light to medium-weight storage. This also accounts for the bending protection of the thin shelves and the rather modest fastening.
For example, placing a small coffee maker or kitchen appliance would be no problem and should hold up well over time. However, for larger appliances such as washing machines, which often weigh over 50 kilograms (110 pounds) and create vibrations, this is extremely critical. The shelving unit is not designed for that purpose, and even if it supports the appliances temporarily, you risk sagging or even breakage in the long run.
There are cases where users have reinforced the shelving with additional cross braces or an extra substructure—this could be an option. If you plan to do this, you should calculate the dimensions and loads as precisely as possible.
Also, consider that the feet or support surfaces of Kallax are not designed to withstand such heavy loads concentrated in a small area.
I hope this helps you.
Aimee schrieb:
Kallax is basically not designed for very heavy appliances.Exactly, and I actually think that’s even a cautious way to put it. You shouldn’t be fooled by the simple appearance—Kallax may seem sturdy, but in practice, it’s really a piece of furniture meant for lightweight use.
usbla schrieb:
The maximum load capacity is around 13-15 kg (29-33 lbs) – which is almost absurdly low when you consider household appliances.It gets interesting if you still want to experiment: one user reported modifying a Kallax with a fitted metal frame—it looked sturdier at first glance, but then you have to wonder why Ikea doesn’t offer something like that if it really provides so much more stability.
In the end: anyone placing their appliances there is definitely risking durability and safety. I’d only recommend it with reservations, and better not on a permanent basis.
Is there anyone who has thoroughly documented experience with years of use in this regard?
Deandre schrieb:
If you want to place a small coffee maker or food processor, for example, that would be no problem and will remain stable over time.Thanks for the detailed explanation. To clarify: I’m more concerned about appliances that weigh around 15-20 kilograms (33-44 pounds), such as bread makers or larger kitchen machines.
GALEO4 schrieb:
In the end, anyone who places their household appliances there is definitely risking durability and safety.That safety concern is exactly my main issue. I definitely don’t want damage caused by tipping or sagging shelves.
Is it really possible to ensure long-term use with additional reinforcements like metal frames? If so, what would you recommend?
