ᐅ Discussion about a shed roof bungalow
Created on: 15 Feb 2015 21:02
wrobel
So, I’ll join in as well...
The plan is for a single-story bungalow with a shed roof designed for two people. The roof pitch will be between 3 and 5 degrees, so quite flat, to keep the living room height just under 3 meters (9.8 feet) while allowing for a ceiling height of 2.6 meters (8.5 feet) in the entrance area.
Living, sleeping, office/guest room, and bathroom will face southwest. A glass facade across the entire width of the house is being considered here (similar to the H_F house).
On the northeast side, a garage measuring 9.0 by 7.0 meters (29.5 by 23.0 feet) is planned.
The slab foundation will be an energy-efficient concrete slab with thermal activation and is planned to be ground and polished before the house is erected.
Heating will be provided by a pellet stove in the living room, combined with solar thermal energy and a buffer storage tank.
I’ll upload the floor plan and would appreciate both positive and negative feedback.
Looking forward to a stimulating discussion.
Olli
Grundriss einer Wohnung: Küche, Essbereich, Wohnzimmer, Bad, Schlafzimmer und Flur auf Papier.
wrobel26 Feb 2016 00:08
Hello
Here is an update on the current status.
The rough-in installation for heating, ventilation, plumbing, and central vacuum system is complete.
Drywall work is underway.
And the front door has been installed.
Olli
Red front door with long metal handle, flanked by narrow glass panels in a dark frame
kbt09
26 Feb 2016 13:41
Looks great
Aventin13 Sep 2017 18:36
If I have understood correctly, the floor construction chosen here (underfloor heating in the form of concrete core activation) does not include a floating screed. Wouldn't this cause issues with impact sound insulation? I always thought that installing a floating screed was practically essential for this purpose... ?
wrobel18 Sep 2017 15:55
Hello
Impact noise within the living area is not an issue.
Only noise from the garage, for example from a trolley jack with metal wheels, is transmitted through the slab.
Olli
Aventin18 Sep 2017 22:40
Thank you for the feedback! From this, I can probably conclude that impact sound insulation can often be omitted in a bungalow without significant disadvantages. (?)
Knallkörper
18 Sep 2017 23:08
Hello Wrobel,
What is the roof structure like? Is it a tongue-and-groove boarding over the OSB panels? And were you able to achieve the slight desired roof pitch, or did the flat roof regulations prevent that?
