ᐅ DHI Planning and Living St. Wendel
Created on: 14 Aug 2014 09:58
Jochen104
After reading and gathering information here for several weeks, I am now ready to participate actively.
We plan to build a house of about 190 m² (2,045 sq ft) plus a double garage in Saarland in 2015.
For this, we have ordered some catalogs from national suppliers and also requested individual quotes. In the end, based on a recommendation, we found the regional company DHI Planen und Wohnen in St. Wendel. They work exclusively with local craftsmen and specialist companies and have built over 400 houses in the last 14 years.
If I understand correctly, I would sign a contract with DHI, who then prepare an offer for the entire construction project and purchase all the building materials. The individual trades are paid directly by me to the craftsmen (according to the offer that was included in DHI’s overall quote). This is said to have the advantage that in case of warranty claims, I can hold DHI liable (because of the contract with them), and if they become insolvent, I can still pay the craftsmen directly.
Has anyone here had experience with the company DHI or can share insights about this billing model?
Thank you and best regards,
Jochen
DJCOON28 Apr 2015 20:50
That all sounds very smooth. I’m quite excited about tomorrow.
DJCOON8 May 2015 22:40
Hello, the rain hasn’t been coming in since yesterday. At least not through the roof anymore.
Quick question: how are things with your tiles? Which company are you working with?
Best regards, Martin
Jochen1049 May 2015 20:31
We no longer have any water entering the building. Today, at least, the protective membrane was installed, and the metal sheets will be added on Monday.
Today, we also finished painting the adhesive barrier and already attached the counter battens, onto which the OSB boards for the attic will later be fixed.
Regarding tiles, the company Stolz is involved in our project. I am already familiar with their excellent quality from other houses. However, we have not selected any tiles yet.
DJCOON31 May 2015 20:56
Hi guys,
how are things on your end!?
Yesterday we received the final invoice from the roofer. The windows will probably be fully installed by Wednesday, before the holiday, so our house will be sealed up by then. Accordingly, the heating engineer will start work after the holiday week.
We will likely begin applying the primer/sealant on Thursday or Friday. Any tips on this? Brush type, mixing ratio, respiratory protection, etc.?
Regards, Martin
Jochen1041 Jun 2015 08:00
Hello Martin,
the roof is on, the windows are installed, and the plasterers have done a really great job upstairs. The ground floor is still pending.
Starting Wednesday, we will install the floor insulation in the living area. I’m curious to see how much effort that will take.
Regarding the primer:
We applied it with rollers in a 1:2 mixing ratio (that’s what we were told). For this, I simply bought two rollers with handles and two roller trays at the hardware store. We also had a slightly larger brush for the corners, my cordless drill with a mixing paddle (you can also do it by hand), a simple bucket for the first mixture, and a meter to measure the amounts for the mixing ratio.
Always roll the rollers on the trays first to avoid spilling the whole mixture on the floor. Then spread it evenly.
For the first attempts, I recommend wearing a cap, long-sleeved clothing, and gloves because it does splash a bit. Or just take a brush with you into the shower. It gets easier over time. In my opinion, respiratory protection is not necessary.
If you work as a team of two, you should be done in 2-3 days.
BaTi_G1 Jun 2015 09:52
we have been running the screed drying program on the heating system for 10 days now... currently a cozy 28°C (82°F) inside the house... but hardly any humidity left... we’ve had really great weather from the very beginning.
In the basement replacement room, I insulated last week, placed the vapor barrier (foil), battens, counter battens, and gypsum boards on top. Inside the house, the drywall contractor installed all the insulation and the vapor barrier. We’ll try doing the battens and gypsum boards ourselves. We’ll start that next week. Right now, it’s simply too warm.
Primer/sealer... only tip is to wear old clothes and a hat... this stuff is hard to get out once it’s on... no need for a respirator... we applied it with a “normal” roller... I think the mixing ratio was 2:1, meaning 2 parts water and 1 part of the product... and it’s best to mix it well with a drill mixer. If you still have time to apply it before installing the windows, I would recommend that... otherwise you’ll have to tape everything off.
Best regards, Timo
