ᐅ Designing Ikea Metod Kitchen Units to Fit Sloped Ceilings Precisely and Functionally
Created on: 20 Dec 2016 09:17
Lanone
Lanone
20 Dec 2016 09:17
Hello everyone, I am currently planning the design of my new kitchen using Ikea Metod kitchen units and facing a real challenge: the kitchen is located in a room with sloped ceilings, so I am looking for a solution that is both precisely fitting and functional.
My specific question is: how can the Ikea Metod kitchen units be adapted to fit optimally under the sloped ceiling without losing storage space or ease of use? Are there proven methods or recommendations for cutting, custom modifications, or suitable additions that are compatible with the standard system?
I have already considered adjusting the wall cabinets but am unsure how best to implement this with the Metod modules and fronts. I am also interested in experiences related to maximizing functionality in such awkward spaces, for example, how to effectively use the space under the slope with practical drawers or pull-outs.
I hope someone here has tips or even practical solutions that have worked well.
jakar
20 Dec 2016 10:43
You can shorten the bottom of wall cabinets; the Metod modules are well suited for this.
Simply place the cabinets under the sloped ceiling and cut off the top moldings. Internal pull-outs help make the most of the space.
For the corner, you can use corner cabinets with carousel mechanisms.
NOAHSAU
20 Dec 2016 13:29
jakar schrieb:
You can shorten wall cabinets at the bottom; the Metod modules are well suited for that.
This is a practical approach, but also quite limited. Ikea produces standard modules designed for straight walls. Under sloped ceilings, it is difficult to achieve a perfect fit and a visually appealing result because compromises in cutting or space utilization are inevitable.
In my opinion, you should either opt for custom carpentry solutions or at least invest a significant amount of time in precise measurements and carefully consider alternative installation options. Simply "cutting off" the cabinets at the bottom is quick but often results in awkward edges and corners that then have to be concealed with accessories for a long time.
I find it surprising how often Ikea is promoted as a cure-all for every kitchen problem, even though rooms with sloped ceilings require a different, sometimes more skilled approach. Those who love the Metod kitchen style should think about how to flexibly complement the modules rather than just force them to fit.
KAMERON
21 Dec 2016 08:52
Regarding the precise and functional design of Ikea Metod kitchen units under sloping ceilings, several aspects need to be considered:
- Accurate measurements are essential, especially measuring the slope at multiple points and lengths.
- Although Ikea does not offer custom angled modules for slopes, the Metod elements are modular and can be adjusted by shortening the upper cabinets at the bottom. It is important that the fronts align well with the slope—this may require custom cuts or adjustments to door colors and handles.
- Using the space under a sloping ceiling often means giving up standard, tall upper cabinets. Instead, shallower cabinets or alternative storage options such as rolling pull-outs, open shelves, or custom-cut drawers are suitable.
- For base cabinets, corner solutions with carousel pull-outs or Le Mans corner cabinets are recommended to make the most of the available space.
- Additionally, angled plinths or panels can be used to adapt to the slope, which can either be made as a DIY project or crafted by a carpenter.
Integrating the Metod elements into sloping ceilings therefore requires a combination of careful planning, precise measuring, and sometimes manual modifications. One approach is to use the standard Metod units as a base and adapt them functionally through custom cuts or specialized inserts.
A tip: It is also worthwhile to use the Ikea kitchen planner software to create an accurate model with the slope and virtually test possible adjustments.
