ᐅ Create an insulated utility room for the gas boiler in the attic.
Created on: 28 Sep 2019 05:57
Golfi90
Hello everyone.
A new neighbor in our development is installing their gas boiler and hot water tank in the uninsulated attic.
In other words, they have a cold roof, just like us.
They said they will build an insulated “box” around the equipment.
Is that possible? If so, it could be an idea for us as well! What should the wall construction of this box be like to ensure effective insulation?
Has anyone here had any experience with this?
Müllerin
29 Sep 2019 21:24
If I had to pull out a retractable ladder every time I wanted to iron, carry the laundry up there, and then carefully fold it back down afterwards... I would never iron. Oh wait, I don’t iron anyway...
Seriously, a proper staircase really makes a big difference—I hadn’t thought of that. Still, I would use the attic as storage space and insulate it. Only items that I don’t need access to often would go up there. The often-mentioned Christmas decorations, for example.
Joedreck
29 Sep 2019 21:28
Phew, sorry, but before I carry those things up a folding attic ladder, I’d rather do it in the garage. There is a huge difference between a fixed ladder and a telescoping one, especially when it comes to the ceiling opening. You really thought this through and did it smartly, but it might not be suitable for everyone.
As a general storage space, yes, but not for regular use like a basement with a retractable staircase. I’m sure about that.
Golfi901 Oct 2019 13:58
I will probably insulate the entire roof. The cost is close to 1000€.
On Monday, we will have a construction meeting with the plumber. There, we will clarify whether to install the heating and ventilation system in the attic.
11ant1 Oct 2019 14:08
Golfi90 schrieb:
On Monday, we have a construction meeting with the plumber. We will discuss whether to install the heating and ventilation system in the attic.
The fact that this can be worked out directly between you and the system installer suggests “building without detailed plans” – this is not necessarily the case, but it can lead to a very abrupt and chaotic process. Let’s hope for the best.
Joedreck
1 Oct 2019 15:29
Also consider preparing for air conditioning from the start. The plumbing system seems to be in good shape.
Golfi901 Oct 2019 16:44
The fact that this can be settled bilaterally between you and the system installer suggests to me a case of "building without detailed plans"—which doesn’t have to happen but could lead to a very chaotic process. Let's hope for the best.
Don’t always assume the worst! There is also site management involved, who stays informed about all agreements in between...
