ᐅ Covering Kallax shelves with leftover wallpaper – is that a good idea?
Created on: 15 Apr 2024 08:47
keoDale
Hello everyone, I am considering redecorating one of my Kallax shelves using leftover wallpaper. I’m wondering if covering the individual compartments with wallpaper remnants is really a durable and visually pleasing solution.
I’m especially interested in whether the wallpaper adheres well to the relatively smooth Kallax surfaces, how durable it is—particularly under the strain of books or decorations—and if issues like bubbling or peeling might occur later.
Have any of you tried this before or can you offer tips on how to achieve the smoothest and most long-lasting results? Which adhesives work best, and is there anything important to consider when preparing the surface?
I’m looking forward to your experiences and advice!
Questions about moisture and durability are important. The wallpaper backing should be moistened carefully, just slightly dampened to make it flexible but not dripping wet, in order to avoid swelling of the substrate.
The surface of the Kallax is melamine-coated, making it water-resistant, so slight moisture from the wallpaper backing will not cause damage if it is processed quickly.
For cutting, I recommend precise measuring and cutting with a sharp blade, preferably leaving a slight overlap that can be cleanly trimmed at the edge with a utility knife after application. This allows for a neat finish along the shelf edges.
To secure the edges, I use a transparent acrylic lacquer or waterproof clear varnish, which prevents peeling in areas subject to heavy use.
In addition to the points already mentioned, I would like to emphasize the importance of surface preparation.
The surface should definitely be cleaned and dusted, if necessary with a mild detergent, followed by thorough drying. A light intermediate sanding improves adhesion.
Wallpaper residues are often not designed to act as an adhesive base, so special attention should be given to the choice of adhesive. Spray adhesive or contact adhesive have proven effective for such applications.
My advice: always apply a test patch first to check adhesion and the result before covering the entire shelf.
Finally: long-term use of the shelf – for example, for heavy books – can reduce durability. For heavy use, options like films or paints tend to be more durable over time.
