ᐅ Delay aging effects on metal shelving.
Created on: 16 Jan 2015 08:42
Manuelbo
I am currently focusing intensively on the topic of slowing down the aging process of Billy bookcases. I am particularly interested in effective ways to counteract typical aging effects on a Billy bookcase. I am not only looking for surface treatments but mainly for sustainable strategies that slow down material fatigue, warping, or color changes.
What are your thoughts? Do you have any experience or tips on how to protect Billy bookcases from aging effects in the long term? I am interested in both physical treatments, possible care products, or even technical solutions.
Thanks in advance for your input!
elgla
16 Jan 2015 15:56
Your observations about the swelling edges and the dulling surface are very common and explain why many people get frustrated. I understand well how stressful it is when furniture no longer looks fresh after a few years.
Personally, I think it’s important not only to focus on the materials but also to consider the role of indoor climate and usage. It can be very helpful to gently roughen the edges with fine sandpaper and then apply a thin layer of clear varnish – this creates a protective barrier against moisture. Of course, this requires some effort, but I believe it’s worth it if it significantly extends the lifespan.
You just need to be careful not to dry out the shelf or seal it too much, as that can cause cracking.
Have you tried this before?
PERON
16 Jan 2015 17:07
Hey everyone! 🙂
Here’s a topic that really goes beneath the surface. Just like a bookshelf or life in general: a little care and gentle treatment make everything last longer. I’m very familiar with swollen edges – sometimes a gentle texture like fine washboard feeling helps. Carefully rub with a slightly damp, soft cloth to remove loose fibers. Then apply a thin layer of beeswax polish and you’re done.
It sounds simple, but these small rituals save us stress and expensive replacements.
So don’t despair right away, and get started on those edges! 😉
LENNAU
17 Jan 2015 08:50
Manuelbo schrieb:
especially for ways to better protect the edges, as they are obviously where moisture attacks the most.
Hello Manuelbo,
You want to specifically minimize moisture damage at the edges. The surface treatment of these edges plays a crucial role. For shelves made of particleboard or furniture panels, I recommend always applying edge banding or edge protection profiles. This provides mechanical protection and significantly prevents moisture penetration.
In addition, impregnating the edges with special wood protection coatings that repel water is advisable. Some hardware stores offer edge protection products or sealing waxes specifically designed for edges made of MDF or particleboard.
If you like, I can provide the exact product names and sources.
Declan55
17 Jan 2015 09:33
LENNAU schrieb:
I recommend always applying edge banding or edge protection profiles to shelves made of particle board or furniture panels.
That’s exactly what I did, and I have to say, it really makes a difference! :-)
Also, regarding color preservation: I’ve made it a habit to spray the shelf with a UV protection spray. This makes the surface more durable and actually reduces yellowing.
Of course, you need to ensure that the spray is compatible with melamine coatings, but most manufacturers provide good recommendations.
This way, the Billy shelf stays looking nice and tough for longer!
blaje2
17 Jan 2015 10:45
Additionally, secure edges with transparent edge protection tape from the hardware store. This protects against moisture and mechanical wear.
Avoid UV light to help prevent yellowing.
