ᐅ Protecting Shelving Units During Transport: Materials and Tips?
Created on: 1 Jan 2015 08:17
Lonijo
I am planning to transport a Billy bookshelf and want to protect it as well as possible from damage. Since the Billy bookshelf is often made from rather lightweight wood or particleboard, I am concerned about scratches, dents, or warping that can easily occur during a move.
Therefore, my question is: Which materials are best suited to protect a Billy bookshelf during transport? What tips or methods do you use to keep the bookshelf stable and intact, especially when moving it disassembled or fully assembled? I would appreciate any experiences with padding, packaging, securing in the van, as well as advice on protecting edges or surfaces from damage.
Thank you!
Thank you!
Lonijo schrieb:
Does anyone have experience transporting the Billy shelf completely lying down?I often transport my shelves fully assembled. It is important to store the furniture on a flat surface, well padded, and secured with several straps to prevent any shifting. The shelf remains fully functional. However, the risk of damage from impacts is higher compared to transporting it disassembled.
Pe_Zeke411 Jan 2015 12:48I have also transported the shelf fully assembled, but only if it can be well supported inside the vehicle. For protection, I used furniture blankets and bubble wrap. The corners were protected with foam. The shelf was then placed on a soft, non-slip surface.
Thank you very much! This also confirms my suspicion that disassembling is safer but more time-consuming. I plan to try securing everything fully with furniture blankets and bubble wrap, and to tie it down tightly. If possible, I will try to protect the corners with foam padding.
My main concern is scratches on the surface, especially if the shelf is pressed against something inside the van. That’s why I will follow the tips for edge protection and padding.
Umberto’s tip is important.
Similarly, the drill holes should be covered with masking tape during disassembly to prevent chipboard fibers from tearing out.
Additional protection tip: Apply a layer of stretch film to the surfaces beforehand. This protects the surface from moisture, and the bubble wrap also shields the shelving unit from dirt.
Good morning,
thank you again for the many helpful suggestions. The advice on protecting the drill holes and covering them with masking tape was new to me and sounds very reasonable. I will try this today and report back on how it went.
Best regards and thanks for the help!
