Created on: 16 May 2021 18:56
Acof1978
- Exterior lighting
Floor plan attached.
Grundriss eines Hauses: Wohnzimmer, Küche, Schlaf-/Kinderzimmer, Bad, Flur, Terrasse.
Neubau2022
28 Sep 2022 14:55
Today we received the long-awaited news. The house handover is scheduled for October 13, 2022 *happy*
And just as importantly, both toilets are already installed :-)
Modern bathroom with wall-mounted toilet, gray tiles, and wooden washbasin.
Modern bathroom with wall-mounted toilet, dual flush button, and light gray tiles.
Benutzer 1001
28 Sep 2022 18:54
The tiler really should have paid more attention to the grout lines. The tile and the toilet should be centered. Maybe it wouldn’t have fit at the edge then, but as it is, it’s not quite acceptable.
Neubau2022
28 Sep 2022 19:06
Offtopic schrieb:
The tiler should have put more effort into the grout lines. The tile and the toilet should be centered. Maybe it wouldn’t have worked out at the edge then, but as it is now, it’s not quite right either.
Then they would have had to start another row on the left side. He already laid out everything before he started tiling. I think it would actually look worse in the end and more tiles would be needed because of the additional cuts. You are probably referring to the photo with the bathtub. For that, you have to take the whole view into account.
Neubau2022
29 Sep 2022 17:22
The heating pipes are insulated. Just 2 weeks left until the house handover. We are excited :-)
Heating room with a white boiler, heavily insulated metal pipes, expansion vessel, and pump.
Neubau2022
5 Oct 2022 06:02
And there was light 🙂 The hanging cable is where a pendant lamp will be installed. The light source can be controlled separately.
Everything you see was done intentionally, and there are no mistakes to fix 🙂
Kitchen under construction: white high-gloss cabinets, wooden base cabinets, window with outside view.
AllThumbs
5 Oct 2022 07:31
Neubau2022 schrieb:
Everything you see was done intentionally, and there are no mistakes that need fixing 🙂
But you are probably the least qualified to judge that. :p
